Focus rs mk1 track car £10500 ono p/x possible
as above , purpose built focus mk1 track car
Car is 03 reg with 25k with history
Interior-
Custom cages weld in cage then full interior repaint base coat and laquer
2x recaro half leather / suede bucket seats with side mount recaro subframes
Trs black 4 point harnesses
350 OMP corsica suede dished steering wheel
carbon fibre door cards
carbon fibre instrument binicle
boost gauge in carbon gauge mount
SPA design oil presure/water temp gauge
Inlet temp gauge
roof vent
suspension-
Gaz coil overs on front with adjustable top mounts (500lb springs)
Gaz spring with adjustable platforms on rear (350lb springs)
Gaz adjustable shocks on rear
Camber shims fitted to rear axle
poly bushes fitted in front lower arms , front arb , rear arb ,rear trailing arms upper and lower , inner and outer
brakes-
AP 6 pot front calipers with 355mm x 32mm discs and bells with ferodo DS2500 pads
Black diamond rear discs with yellow stuff pads
Braided flexi hoses throughout
AP racing super blue brake fluid
drivetrain-
standard frs gearbox with new selector shaft and seal so no leaks at top
oil changed 6 weeks ago and never been used
AP racing paddle clutch
4 x new wheel bearings fitted less than 1k
Team Dynamics pro race 1.2 8x18
Toyo R888 225/40x18 gg
engine-
standard frs bottom end (only done 25k)
Standard cyl head
Custom inlet cam
Primary designs GT28 turbo
Primary designs bradded oil line
Primary designs inlets pipework
Owen developments actuator
r-sport front mount intercooler , (2 month old , pro alloy one had leak)
Pro alloy radiator
Pro alloy swirl pot
Spal 12" sucker fan
silicone coolant hoses with heat wrap where req'd
oil cooler mounted front of o/s/f wheel
power steering cooler mounted slam panel
new power steering pump fitted
Cosworth style bailey breather wirth correct oil return into sump (all standard kit removed)
Vibra technics mounts on engine , gearbox and torque link
Tubular manifold (make unknown poss PD but no reciept)
Primary design divorced downpipe
Milteck stainless system with 100 cell sports cat and also decat pipe
there may be bits ive missed but as you can see this car is ready to go and has all the right bits fitted
price is £10500 ono , p/x is possible if you are realistic with price
contact me on 07770927234
car has a few marks here and there and small dent in n/s 1/4 that i will add picture of later
Interior-
Inlet temp gauge
roof vent
suspension-
brakes-
drivetrain-
engine-
Standard cyl head
Custom inlet cam
Pro alloy radiator
Pro alloy swirl pot
Spal 12" sucker fan
track.focus'd
Aug 12, 2015 05:53 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
Versus_Creations
24
Aug 5, 2015 09:32 PM
