learn new things everyday
stripped a 2ltr dohc auto ghia sapphire
i did not know that any sierra came with heated washer jets and the rear spoiler was the same as the cosworth but had a brake light in it and it was hollow so super light compared to the cosworth one , this car must have had all the little extra stuff , car had only done 58 000 or not much more
yea its just the first one i have seen with them lol broke loads of them too lol , and yea we were thinking that as it was held on with screws but it could be a good upgrade maybe , also had the chrome in the window rubbers , eletric sunroof , tweeters in the speakers , fog lights, lights for the foot well , abs,air con, disc rear , colour coded bumpers/eletric mirrors,heated screen,same shape steering wheel apart from it never had leather round it , sapp cosworth type grill was good to see all the extras on it
You've broken a 92 spec ghia demo car from the sounds of it
They came with a lot of kit but the hot jets are nothing new, they were part of the hot screen options so if you had a hot screen they wired them in as well
The electric roof was a 92 upgrade which gives the year away and the speakers were of higher spec too on the front and the rear
Martin
It just plugs onto the hot screen loom mate
Or piggy backs?
They just have different plugs depending on the year, square or oval from what I can remember, my mate had them in his 91 spec 2000E and also on his 90 spec ghia 4x4 estate
Or piggy backs?
Martin
the "90 spec" was the 1990 facelift onwards, which gave the smoked lights at the rear, clear front indicators, deleted the under dash speakers and gave a larger glove box on the passenger side plus the addition of the drivers side glove box, the different central locking setup (which meant different doors), different heater controls, the introduction of all disc brakes on the dohc engined cars, different seat fabrics, true twin din centre console stereo set up, a redesigned upper and lower dash board (all 3 parts), remote boot and filler cap opening, deletion of the boot push lock and a different shape for some of the wiring plugs and sockets
the "92 spec" facelift saw the wrap around upper dash, different heater controls yet again, a smaller instrument cluster, different door cards with 4 screw door handles instead of 3, electric sunroof options, no more trip computer, single rear number plate light (other than the cosworth, which retained the older double light set up), body coloured bumpers across the range, abs as standard on the gls models (previously only standard on the ghia and cossie models, there is some debate as to when they standardised it on the xr range as some still came without and some were badged as ghia models on the estate versions, they were optional on all but the cossie on everything before the 90 spec, even the 2000e) and so on and so forth, and they changed the plug connector shapes again, now including a triangle and square shape to replace the older round and oval versions
i'm sure there were other changes but these are the main ones that are noticeable and can tell you if you've had a car made in one year or another and also the easiest things to change if you want to update your car to the latest specs
everything is interchangable along the way
Mark_
40
Oct 2, 2015 04:40 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
The head was frozen but at least the water jets were fine
