Anyone know where I can get some 5mm spacers that will fit inside a brake disc? I'm fitting 2wd cossie brakes into a RS2000 but they hit the ball joints I had this when I used the FRS setup but as the disc's where so big a normal wheel spacer would fit inside those!
I guess I could but wouldn't be able to on a milling machine as it would go into the holes so would have to use a grinder or something quite a lot needs to be removed
A used washers on ma track car never gave any probs two m12 washers on each stud then fitted disc no the ideal answer but was a cheap fix and it wa only for track but as said it never gave any probs and it been to abt 15 track days.
Cheers marc
Just been out test fitting i need 8mm to clear the balljoint which is 3 washers
