Brake disc's need spacing out
![Question](https://passionford.com/forum/images/icons/icon5.gif)
Anyone know where I can get some 5mm spacers that will fit inside a brake disc? I'm fitting 2wd cossie brakes into a RS2000 but they hit the ball joints I had this when I used the FRS setup but as the disc's where so big a normal wheel spacer would fit inside those!
I guess I could but wouldn't be able to on a milling machine as it would go into the holes so would have to use a grinder or something quite a lot needs to be removed
A used washers on ma track car never gave any probs two m12 washers on each stud then fitted disc no the ideal answer but was a cheap fix and it wa only for track but as said it never gave any probs and it been to abt 15 track days.
Cheers marc
Cheers marc
07-10-2015 12:56 PM
