Focus Rs mk1 Nmm
Just thought I'd start a bit of a thread for my Rs never done one of these threads before so not too shure what to say so ill start putting sum pics up of it
RRight while you asked so nicely just been looking not got any pics from the next stage was wnt much to see any way
So when I picked it up it was compleatly standard it lasted around 2 weeks like that! First mods wer a full miltek exhaust with a de cat and a k&n panel filter and a forge actuator with a fillerphil easy adjust running direct and a forge 007p recirc and a dpc stage 3+ map. The car made 295bhp with this set up and it pulled like a train! All set up by Johnfrs
it lasted about a month before I got busy again this time I fitted some roose boost hoses and intake hose and recirc hose then after a conversation with Johnfrs I got johns next generation hybrid fitted up to be tested on my car to see how it performs before he started making them for others
pic of the new comp wheel in the back plate compared to the standard wheel! Got to say this is the single most best mod on the car utterly transformed the car! With the same set up above plus the hoses and hybrid the car made 320 bhp at the same boost as before too!
Few more pics of the turbo this is the big comp wheel in the standard housing
then the standard wheel in the enlarged housing
and here's a pic of the easy adjust not mine tho didn't get any pics of it this one is stickys
also fitted a splitter too having a bit of trouble with kurbs tho!
ill do another update tomorrow it's taking forever on my phone! Few pics of mine and Johnfrs' car to finish off
pic of the new comp wheel in the back plate compared to the standard wheel! Got to say this is the single most best mod on the car utterly transformed the car! With the same set up above plus the hoses and hybrid the car made 320 bhp at the same boost as before too! Few more pics of the turbo this is the big comp wheel in the standard housing
Well seeing that I've been prompted I best do an update I think so here gose
pic of it with the new boost hoses heat sheild is off the mani because the hybrid had just been fitted
then next up I fitted a tubular manifold
that pic is from midway through fitting it but you get the idea the car was then re dynod and made 360bhp at 22psi it drives so well now with the mani and hybrid will get me in to trouble one day ha ill do another update tomorrow
, had to find this thread on the 3rd page, (glad I know what's coming in the updates)
Time for an update??
