strange knocking/rattle at low revs
I have developed a new rattle / knocking noise on my mk3 tdci.
Car ticks over fine at 800 rpm, and no noise, other then normal diesel engine noise.
When I pull away, it has a loud rattle knocking noise but goes when I hit 1000 rpm and engine is quite. It sound like its coming from the alternator side, defo not gearbox side.
Its the same in each gear. It gets better after about 15min drive. Had new pulleys 2 year ago.
Any ideas? Only really noticed it after my new exhaust was fitted. Might be just a coincendance? Don't think its a heat shield as don't sound tinny.
Should be dan, only had its mot done 2 weeks ago. That's when the exhuast was fitted. Would of thought it would of been spotted if mounts where loose or warn.
The MoT is no guarentee of roadworthyness! Worth getting them checked out as its a simple fix if it is one of them.
Get your head in the engine bay and have a good look around for anything wobbling. Look at the belt and make sure it's running 'true'. It was all swapped, but it's a Mk3 weak point.
the belt tensioner can go "soft" and let the belt jump on tickover/drive takeup
they are a bitch to change aswell
failing that, harmonic damper (crank pulley) can fail too
had a transit in on monday, it was still "in place" but when he turned the steering all the pulleys stopped and he lost steering assist, cut the belt off as the tensioner was seized and the crank pulley fell in half when i pulled the belt!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
