Diesel leak from somewhere
Old Feb 19, 2013 | 06:09 PM
Jimbo2260's Avatar
Jimbo2260
Default Diesel leak from somewhere
Good evening everybody, I am a new member here so I will introduce myself in the "introduce yourself" forum if it has one
I am new to fords due to owning numerous rover diesels, and decided it was time to upgrade the motor. Bought a mondeo 130 TDCI zetec with 125000 on the clock, and in excellent condition (loads of cool gadgets that I have never had on other cars!)
Here's the problem, after driving the car there is a small diesel leak coming from underneath the car, nothing major, but after a few hours there are a few drips of fuel on the floor. I have tried to locate it whilst the car was on jack stands but could not. I cleaned it up and had the engine running and there was nothing. It only seems to do when the engine is under load I.e while driving. I am hoping that it is a loose something or other and not leaking from the pump. There does not seem to be many answers on the net as I have googled it (that's his I found the forum) so I hope somebody can help me
Many thanks for taking the time to read this
James
Old Feb 19, 2013 | 06:18 PM
cossiejay's Avatar
cossiejay
welcome to the site I am sure you will find someone on here who can help
Old Feb 19, 2013 | 06:26 PM
stevo123's Avatar
stevo123
Hi, I dont want to sound sarcastic but have you had a look underneath?
Most local tyre and exhaust plates would let you use the ramp for a few minutes possibly (to save you scrabbling about on the floor). Its probably a damaged fuel pipe or something like that hopefully.
Hope you get sorted mate.
Steve
Old Feb 19, 2013 | 06:27 PM
spot1's Avatar
spot1
Just had the same on my ford Transit and it turned out to be the fuel metering solenoid,its a common fault on the transit and i think they may share the same pump.
Old Feb 19, 2013 | 06:35 PM
Jimbo2260's Avatar
Jimbo2260
I have had it in jack stands, I do a lot of my own work on the car so invested in a few tools or the job! I did read about the transit situation on the Internet, how much did it cost you to fix? I am hoping its nothing less than Ł100 to sort it out I.e fuel line or something. Is there a common problem on the TDCI mondeo engine for leaks? I know it is not coming from the injectors as there dry. Not sure about the leak of pipes as they disappear down into the engine bay
James
Old Feb 19, 2013 | 07:27 PM
spot1's Avatar
spot1
Hi James,not good news if it is the same fault as mine as the solinoid is Ł288 but it is easy to fit.It fits in the middle of the fuel pipes on front of the pump.
Old Feb 19, 2013 | 08:32 PM
Jimbo2260's Avatar
Jimbo2260
Just got back in and was horrified!! Out my foot down because I stalled it ( not used to the clutch ) and the gauge went from quarter of a tank to nothing! Fuel light was on and the dash comp went from 150 miles till refill to 16!!! Got to a garage and put Ł20 in and now it is at half with 250+ miles to refill on the computer. Are these things actually accurate? Or is this something to do with the leak? Ł288 is better than Ł750+ for a fuel pump (if its leaking from there that is) any other info will be greatly appreciated. Going to have it back up on stands at the weekend
Many thanks
James
Old Feb 19, 2013 | 10:23 PM
spot1's Avatar
spot1
Have a look for a shop on line called diesel jones,that is where i got my bits from was the cheapest and very quick.
Old Feb 20, 2013 | 02:54 PM
Jimbo2260's Avatar
Jimbo2260
Will do spot1 are there any other places were it could possibly leak from? Like I said, the top of the engine is dry so it's not coming from the injectors themselves
Many thanks
James
Old Feb 20, 2013 | 09:03 PM
Jimbo2260's Avatar
Jimbo2260
Just had a thought, does the transit not have the Bosch vp30 or 37 pump? I recall reading about it somewhere. The mondeo has a "delphini" pump unless the later transits upgraded the pump?
Old Feb 20, 2013 | 09:38 PM
jamie's's Avatar
jamie's
theres also a seal on the front of the pumps that are knwn to fail and leak diesel
seen this a few times, but always transits, so maybe not mondeo's
Old Feb 21, 2013 | 08:57 AM
spot1's Avatar
spot1
yep mine is a bosch vp30
Old Feb 21, 2013 | 11:06 AM
steviebannana's Avatar
steviebannana
(MercinarymechanicS)
hi im new, now a thing or 2 about diesels. cud be on of the returns or main return back to the pump or tank, ford used plastic ones, chaffed and wee out like a spray, more throttle the more deisel u loose. just a thought?
Old Feb 21, 2013 | 01:35 PM
Jimbo2260's Avatar
Jimbo2260
I didn't think of that!! Will check all over when I get some time!! Working all week an now Saturday and Sunday,
Old Feb 22, 2013 | 03:33 PM
Jimbo2260's Avatar
Jimbo2260
Well, I have checked as much as I can and I still cannot find the leak, I am 70% sure it's coming from the fuel pump area, as that seems to be the wettest. But from what little I can see of the pump I can't see anything leaking from it specifically. I've dried it all up an revved the engine in neutral but it doesn't seem to reappear that way. All leak of pipes are good, fuel lines are good and the injectors are good ( touch wood ) I take it there are no common leaks on this model of engine? It's too cold to keep looking now so I have given up, been out there an hour patiently waiting to see a trickle or spray but nothing
James
Old Feb 25, 2013 | 04:27 PM
wulliegunn's Avatar
wulliegunn
dont buy a new pump if its knackerd. I got 1 for Ł250 refurbd.lasted years til eventually i sold her on
Old Feb 26, 2013 | 03:07 AM
Jimbo2260's Avatar
Jimbo2260
Ate they plug and play? Or do they have to be re-coded to the engine? Can I do it my self or is it a garage job?
Old Feb 26, 2013 | 09:10 AM
wulliegunn's Avatar
wulliegunn
dunno about mondeo's but my common rail diesel pug was just plug n play.knowing ford they'll probably need coding tho lol.
timsrs
Nov 13, 2018 11:48 AM
Fudgey
21
Sep 30, 2015 06:19 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Bighandsuk
Sep 2, 2015 05:23 PM
