Non Ford parts & other stuff for sale If its not for a Ford, or even not car part... this is the room to sell it!! Starting a topic requires you to have purchased a gold membership.
GT Ruckus Mountain Bike
Old Feb 18, 2013 | 07:28 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Default GT Ruckus Mountain Bike
Doesn't get used anymore so may aswell go if i get the right money for it!
Frame & Fork
Frame Construction TIG-welded
Frame Tubing Material GT Ruckus design, revised dirt Jump geometry, 6061 AL
Fork Brand & Model Manitou Stance Static, 100mm
Fork MaterialAluminum/magnesium
Rear ShockNot applicable
Components
Component GroupMountain Mix
BrakesetHayes Sole, hydraulic disc, V6 160mm rotor brakes, Hayes Sole levers
Shift LeversSRAM, X-7 trigger type
Front DerailleurTruvativ BoxGuide
Rear DerailleurSRAM SX-7, Med cage length
CranksetTruvativ Hussefelt DH,, 36 teeth
PedalsDMR V12
Bottom BracketTruvativ Howitzer XR
BB Shell WidthUnspecified
Rear Cogs9-speed, 11 - 32 teeth
ChainKMC Z9000
SeatpostSDG, I-Beam, AL 6061, 25.4mm diameter
SaddleSDG, FRD I-Beam, stitched cover
HandlebarDMR Wingbar
Handlebar ExtensionsNot applicable
Handlebar StemSpecialized
Headset1 1/8" TH Mallet
Wheels
HubsFront: Alloy, disc type, sealed bearing, 20mm through axle, Rear: Alloy, disc type, 9-speed cassette, 135mm spacing, nutted axle
RimsSun Single Track SL-1, double wall, 36H, 36-hole
Tires26 x 2.40" Kenda Cortez
Spoke BrandStainless Steel, 14ga. (2.0mm) Straight Gauge
Spoke NipplesCP Brass
This is a seriously strong bike as you can see by the strengthening places and welding
£1200 new imported from America several years back, has a few battle scars, nothing that effects its performance or durability.
Looking for offers around £300
Text would be best option on 07710622695
Old Feb 20, 2013 | 05:08 AM
rich frst's Avatar
rich frst
Why so far away. Need a good bike for work
Old Feb 20, 2013 | 08:28 PM
Cosnada's Avatar
Cosnada
Is the bike stand for sale?
Old Feb 21, 2013 | 06:40 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Always the way unfortunately, its either close and over priced or miles away and cheap
Sadly not mate
sridgett
Oct 1, 2015 07:30 PM
Andypandy260
Sep 23, 2015 10:28 PM
STAFFY OWNER
Sep 13, 2015 08:59 PM
Shows & Track Days
Sep 4, 2015 07:16 AM
