Gripper into cossie diff
Old Feb 12, 2013 | 10:35 AM
ClevoCapri's Avatar
ClevoCapri
Default Gripper into cossie diff
Hi team,
What is rquired to fit a gripper centre into a 7.5" cossie diff?
Ive read the case needs grinding, same as a quaife or any other centre realy.
What else does it need?
What drive flanges do you use and do you need to modify them?
Any help appreciated.
Brett
Old Feb 12, 2013 | 11:37 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I had to gride out the o.s side of the casing buy a fair bit and lift the diff into the casing with the crown wheel lose on the diff! Then once in there bolt the crown wheel to the diff! I also fitted the bearings after but do know if you can or can't get the diff in with bearings on hope that made sence lol
Old Feb 12, 2013 | 11:45 AM
RS_Gav's Avatar
RS_Gav
Here is what you do... Give it to me and I'll sort it out mate!
Old Feb 12, 2013 | 11:46 AM
ajamesc's Avatar
ajamesc
It's an easy job!
Old Feb 12, 2013 | 12:22 PM
ClevoCapri's Avatar
ClevoCapri
Do you have contacts you havent told me about?????
I do want to track it. Not just have pretty pics taken for magazines.......
Haha, jokes mate! Do you have any pics from your shoot?
Old Feb 12, 2013 | 12:23 PM
ClevoCapri's Avatar
ClevoCapri
Originally Posted by ajamesc
It's an easy job!
Cheers for the info.
Any dramas with the drive flanges?
Old Feb 12, 2013 | 12:31 PM
RS_Gav's Avatar
RS_Gav
Hahaaa!! Touché.
I have all the high res originals. I will get around to printing a few up one of these days.
Old Feb 12, 2013 | 01:42 PM
ajamesc's Avatar
ajamesc
they bolt in with a gripper so your originals will need drilling down the middle then you need too long bolts and a bit of silicone job done the bolts are m8 and need to be about 5mm longer than the flang!
Old Feb 13, 2013 | 12:27 AM
ClevoCapri's Avatar
ClevoCapri
Ok cool.
Thanks for that, I appreciate the info!
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
