Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Mk5 Fiesta - can door locks be rebuilt?
Old Feb 12, 2013 | 09:24 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Default Mk5 Fiesta - can door locks be rebuilt?
Folks,
Got a tidy wee mk5 Fiesta just now but the driver's door won't open with the key. Had a few like this now, and the key works fine in every other lock, including ignition!
Is there any way to rebuild the lock barrel to suit the key?
Old Feb 12, 2013 | 09:43 AM
cossiestu's Avatar
cossiestu
Yep, should be able to get a kit from Ford. Fiddly, but do-able!
Old Feb 12, 2013 | 10:16 AM
STeve's Avatar
Super Moderator
Definitely can
Old Feb 12, 2013 | 10:34 AM
Zetec_mk4_XR3i
Cheers - will give them a phone!
Old Feb 12, 2013 | 10:37 AM
dojj's Avatar
dojj
Resident Wrestling Legend
get a lock kit and it comes with all the bits to rebuild them inside
very fiddly but doable
Old Feb 18, 2013 | 08:49 AM
brioni's Avatar
brioni
I have a similar problem when trying to unlock the drivers side- there's a knack to it. both keys are the same but the passengers lock works ok.
question- do both locks operate the same? if they are identical, is it feasible to switch them over? I don't mind having this issue on the passenger side!
Old Feb 18, 2013 | 11:24 AM
Zetec_mk4_XR3i
I think they are sided but possible to swap, can anyone confirm?
Old Feb 18, 2013 | 04:23 PM
dojj's Avatar
dojj
They should be sided, otherwise when you lock it it will be openable with any ford key
It's fairly simple to change the lock barrel around but is it worth it when the rebuild kits are only about £20?
Old Mar 15, 2013 | 12:38 PM
thegfb's Avatar
thegfb
Skint V6 owner
The kits from Ford are now about £40+VAT
Keep an eye out though, just got a brand new one on ebay for £10.50 Just need time to sort it out now.
JoeyBoyden
Jan 4, 2024 02:36 PM
PaulinhoT
Oct 28, 2015 06:06 PM
RockinRein
Aug 19, 2015 07:08 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
turbobill
Aug 1, 2015 08:55 PM
