safe boost
Old Feb 9, 2013 | 11:14 PM
t5frankie's Avatar
t5frankie
Default safe boost
Hi what is the max safe level of boost i can run on my cossie on a t3 with greens? thanks
Old Feb 9, 2013 | 11:38 PM
botters's Avatar
botters
competant bodger
whatever the chip was setup for, mine was done at motorsport developments and held 1.5 bar
Old Feb 9, 2013 | 11:47 PM
t5frankie's Avatar
t5frankie
i know but it has a stupid bleed valve on so i dont know what its supposed to be
Old Feb 10, 2013 | 12:27 AM
eel-roy-t5r's Avatar
eel-roy-t5r
have a look on the chip , might have it on there
Old Feb 10, 2013 | 08:17 AM
t5frankie's Avatar
t5frankie
Got told it's a Harvey Gibbs stage 3
Old Feb 10, 2013 | 08:22 AM
LHD220Turbo's Avatar
LHD220Turbo
get rid of the bleed valve, open the ecu and the chip will have a serial number on it if its a decent chip.
ring the company of the chip quoting the serial number and they will tell you the parameters
personally, i would just get it set up with a fueling check to be 100% sure its correct, otherwise you'll end up melting your engine
Old Feb 10, 2013 | 10:15 AM
eel-roy-t5r
could be anything tho , best of having a look to be safe
Old Feb 11, 2013 | 01:07 PM
martysmartie's Avatar
martysmartie
It's impossible to say, there isn't simply a generic figure. It depends entirely on your setup/mapping etc, best way is to get a RR session booked and make sure you are safe!
Martin
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
