saff cosworth 4x4 front shocks vs escort cosworth 4x4 front shocks
Old Feb 9, 2013 | 02:00 PM
COSSY DALE's Avatar
COSSY DALE
msd tooned 380+ bhp
Default saff cosworth 4x4 front shocks vs escort cosworth 4x4 front shocks
information needed
are saff cosworth 4x4 front shock absorbers the same fitment type as escort cosworth 4x4 shock absorbers
i.e will escort cosworth front shocks fit on a saff 4x4 cosworth with no fitting problems ????
Old Feb 9, 2013 | 02:04 PM
The Youth.'s Avatar
The Youth.
yes they are exactly the same
steve
Old Feb 10, 2013 | 08:32 PM
mk22door's Avatar
mk22door
Fart of the Purniture
They aint.
Escos spring cup is higher than the 4x4 Saff spring cup.
Old Feb 10, 2013 | 08:34 PM
mk22door's Avatar
mk22door
Escort on the left
Old Feb 10, 2013 | 08:35 PM
mk22door's Avatar
mk22door
other than that they are the same.
Old Feb 11, 2013 | 04:27 PM
matthewpickup's Avatar
matthewpickup
well done i thought they were the same lol
Old Feb 11, 2013 | 04:56 PM
The Youth.'s Avatar
The Youth.
I though tit was just Koni's that had the shorter spring cup!
every day is a school day!
steve
Old Feb 11, 2013 | 07:30 PM
mk22door's Avatar
mk22door
All I can tell you is the struts in the picture are both original, not aftermarket.
It was Dojj who told me.
Old Feb 12, 2013 | 01:14 AM
ELFRANCO's Avatar
ELFRANCO
Hi mate whats the measurement from the bottom of the shock to the spring cup if you dont mind measuring both shocks.........Cheers
Old Feb 12, 2013 | 01:28 AM
mk22door's Avatar
mk22door
Sorry mate the Escort struts have been fitted to my Saff and the Saff struts I didn't end up buying.
Old Feb 12, 2013 | 04:25 PM
ELFRANCO's Avatar
ELFRANCO
No prob mate, cheers
Old Feb 12, 2013 | 09:50 PM
matthewpickup
out of intrest dose that mean the escort is heavier on the front or are the springs shorter ? as the spring seat being higher it would lift the ride hight of the car ?
Old Feb 12, 2013 | 11:02 PM
mk22door's Avatar
mk22door
I doubt the escort is any heavier than a 4x4 Saff, I don't know the reasons why the spring cup is higher?
The EScos had 8x16 wheels where as the 4x4 Saff had 7 x15? I think?
I'd hazard a guess at it being to do with fitting the wheels they had in mind with the 4x4 Sierra stuff in the escort wings?
I really don't know mate
Old Feb 13, 2013 | 09:12 PM
matthewpickup
i think your spot on with the wheel width as i have 7.5" wheels on the 4x4 sierra cosworth set up with coilovers and there is not much room between coilover and tyre at 8" i recon it would be on it or a baw hair space lol
Old Feb 13, 2013 | 09:21 PM
Marc sierra's Avatar
Marc sierra
The Escort wheels still fit a sapph. I think it's more the tyres that are used by the Escort that might be a problem to fit a sapph. 225/45 R16 is a bit bigger than the 205/45 R16, which the sapph would need to keep the same tyre radius as standard.
Fitting the Escort struts to a Sapph would increase the ride height on a Sapph though.
Old Feb 13, 2013 | 09:30 PM
matthewpickup
thats a fairly wide tyre at 225 , i run 215 and dont think i would go wider on the front as its always good to see day light between a moving bit and a bit that dose not move lol , it would be down to wheel offset too so alot of diffrent ways to mess around with
Old Feb 13, 2013 | 10:34 PM
mk22door's Avatar
mk22door
I've yet to see how it's going to pan out with the ride height.
I was wanting to find some lowering springs for a V6 xr4x4, when I dug into it all the part numbers where the same for 4 & 6 cylinder models - I would expect the V6 springs to be a different rate for the extra weight of the engine, but not, even one supplier told me they are all made the same!
Anyway, I stick the BOA in my Saff using all the Granada 24v stuff minus the shocks and springs - I found the Escos struts local, cheap and only done 40 thousand miles, at that time I couldn't find any cheap second hand XR struts so slapped them on with standard sierra pinto springs Just to get it rolling again as it's in a friends garage getting welding etc and he wanted it to be moveable.
I think dojj has since said about the ride height, but i'm hoping if I get some decent springs and the weight of the engine might balance it out - shall have to weight and see.
Old Feb 13, 2013 | 10:38 PM
matthewpickup
you could talk to gaz and get two coilovers speced for the car with that engine , dont think it will be cheap mind you my two front were around £350 i think and that was them speced to the pickup with its engine
Old Feb 13, 2013 | 10:44 PM
mk22door's Avatar
mk22door
Yeah, a bit out of my reach that mate
James Porter
Aug 26, 2015 10:51 PM
Old ford
Jul 31, 2015 06:50 AM
