Various engine bits and more! priced to clear hopefully...
Engine Machinist
prop spacers and bolts SOLD.
CPS and bracket (no idea if it works) £5
tensioners £5 each
cossie clutch pivot arm and bearing, not sure if its 2wd or 4x4 £10
dizzy drive shafts £5 each
dizzy drive shaft seal housing £5 each
front main seal housing (slight bit broken off, but nowhere important. can be seen in pics) £5
PAS pump bracket £5
throttle cable bracket £3
std cam pulley £3
alternator bracket £5
3 bar map sensor (has been repaired with plastic weld where pipe broke off, fully functional last time i tried it) £10
Escos door liners (the foam things), one opened, one unopened £SOLD
seat runner covers SOLD
rear konis, need recon £10 pair
16mm arb £5
4x4 front hub £15
Champion coil on plugs. from a rover v6, came from brand new engines that hadn't been fitted in cars. £15 each
unbranded steering wheel, £10
Books £3 each, leaflets £2 each
all prices exclude postage, paypal or cash please!
Engine Machinist
andy- you're second in line for the runner covers as i had a pm late last night for them.
jeff - pm'd
paul - replied
rob - pm'd
rog - pm'd
steve - noted
thats all for now!
jeff - pm'd
paul - replied
rob - pm'd
rog - pm'd
steve - noted
thats all for now!
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
