Focus RS mk1 4x4
Feb 4, 2013 | 09:35 PM
Focus RS mk1 4x4
Feb 4, 2013 | 09:38 PM
Feb 4, 2013 | 09:44 PM
Feb 4, 2013 | 10:59 PM
Look's a lovely car
who did the fab work ?
Feb 5, 2013 | 06:51 AM
A1 Rallysport, and Mk Motorsport did the hubs tca's comp struts etc
Feb 5, 2013 | 11:34 AM
Definitely some nice bits going into it
Front strut tops look very wide apart.
have you mocked it all up with 4x4 suspension?
Got good camber angles?
Feb 5, 2013 | 04:09 PM
Wow this is well smart.Some nice parts there.I take it your using cossie running gear.
Feb 5, 2013 | 04:19 PM
Feb 5, 2013 | 04:52 PM
Quote:
Originally Posted by
Very nice
Nice job good to see one done not useing a 4x4 floor
Feb 5, 2013 | 09:08 PM
Feb 5, 2013 | 09:11 PM
Feb 5, 2013 | 09:15 PM
Feb 5, 2013 | 09:19 PM
liking alot!!
Feb 5, 2013 | 09:24 PM
custom boost pipes
wiggins
off turbo
Feb 5, 2013 | 09:27 PM
how dos it set up with the strut tops were they are(front) then just intrested as its 4x4 ,looks good so far
Feb 5, 2013 | 09:28 PM
custom intercooler with air dam
Feb 5, 2013 | 09:31 PM
coming together nicely......
Feb 5, 2013 | 09:48 PM
dingla rs
Exactly what i was asking Andy
It does'nt look like the front suspension mounts have been moved in to replicate the sierra ones so the front shocks may be standing up to straight
every 4x4 focus ive seen has had the strut tops moved in to 40" centres from the focus setting of 42"
Shaun have you mocked the front suspension in?
Only trying to help and learn not picking faults
David
Feb 5, 2013 | 10:02 PM
that looks proper that mate, hope you get some top notch engine mounts on it tho pal as with all those solid hoses on some damage will be caused if it snaps a mount which is common with the 4x4's
looking forward to updates on this
Feb 6, 2013 | 01:30 PM
Feb 6, 2013 | 05:44 PM
Quality build
Feb 6, 2013 | 05:50 PM
Engine bay looks stunning
Feb 6, 2013 | 05:51 PM
Cracking build keep up the excellent work
Feb 6, 2013 | 05:54 PM
Anyone on here own a 5 door mk1 focus? If so please could you measure the depth (or if you like width) of you door sills? This being from under the rubber/sponge draft seal to the point where the bodywork drops down. On my 3 door mk1 it is 65mm and would just like to check if they are the same? Anyone who could do so would be doing me a massive favour.
Thanks guys.
Feb 6, 2013 | 07:27 PM
botters it looks like hes running vibertechincs mounts
Feb 6, 2013 | 08:11 PM
whizzisat114
David
Feb 6, 2013 | 08:13 PM
graham c
the engine was only in for mock up its back out now, not using those engine mounts
Feb 6, 2013 | 09:59 PM
shaun_focus4x4
Thanks Shaun that's cleared it up for me
Good luck with the build
David
May 14, 2013 | 07:14 AM
new stoppers
May 14, 2013 | 08:24 AM
May 14, 2013 | 08:28 AM
Love it! Can't wait to see more...
Jun 23, 2013 | 11:27 AM
and the rears
Jun 23, 2013 | 11:28 AM
will hopefully be done for ford fair
Jun 23, 2013 | 03:45 PM
They look great
Are you having separate handbrake calipers?
Or do these have that feature built in to them?
Jun 23, 2013 | 03:55 PM
will be running a hydraulic handbrake and will prob just use a hydraulic line lock
Jun 23, 2013 | 06:08 PM
Oh I thought you had to have a mechanical handbrake to pass an mot?
Jun 23, 2013 | 06:24 PM
That looks really nice that
Jun 23, 2013 | 06:50 PM
yeah I believe you do. that wont be hard to add on at a later date
not too fussed about having it on the road at the min, it'll be abit too harsh for the roads round here (pot hole central)
Jun 23, 2013 | 07:42 PM
Jun 23, 2013 | 08:50 PM
