Compression strut, anti-roll bar then?
Old Feb 3, 2013 | 09:47 PM
MalZon's Avatar
MalZon
Default Compression strut, anti-roll bar then?
Once you have replaced the anti-roll bar with compression kit, how have you done to replace the anti-roll bar?
I just mounted compression kit on my Cossie, so now I have no anti-roll bars and are concerned that traction will suffer ..
Please show pictures of what you have done!
Regards/Jonas
Old Feb 4, 2013 | 08:39 AM
Paul_RS's Avatar
Paul_RS
You are supposed to fit a bladed front ARB like on the rally cars. Don't have any photos though.
Old Feb 4, 2013 | 10:08 AM
neilnewboy's Avatar
neilnewboy
I too am interested in this type of setup, my post has some info
https://passionford.com/forum/genera...mp-struts.html
Old Feb 5, 2013 | 06:52 PM
MalZon's Avatar
MalZon
I got the piont then. So any pics?
Regards/Jonas
Old Feb 11, 2013 | 03:03 PM
Marc sierra's Avatar
Marc sierra
My car has a kit from Suhe Motorsport (I think) fitted, it was already there when I bought the car so I'm not sure on where it's from. It still has the standard arb and uses compression struts below the arb.
It's a bit like what the Minker from Turbo Technics also had:
Old Feb 12, 2013 | 04:58 AM
MalZon's Avatar
MalZon
Interesting, I was thinking about Sellholm model. Any tried that?
Regards Jonas
Old Feb 12, 2013 | 09:08 AM
DaveCrack's Avatar
DaveCrack
Never heard of that. Do you have any pics of the setup?
Old Feb 12, 2013 | 12:16 PM
RS_Gav's Avatar
RS_Gav
I am thinking about doing the same thing. A mate of mine sent me these pics of his.
The bladed ARB kit he has included box sections the need to be welded to the chassis rails to mount the tube part of the blade.
Old Feb 12, 2013 | 12:59 PM
McGoo 69's Avatar
McGoo 69
im in a similar position atm
i have comp struts and want to fit them to my car along with a arb and adjustable tca..
the only problem is i cannot find a arb that bolts onto the standard adjustable style tca... i can only find arb's suitable for rally/wrc tca's?
where can i buy tca's suitable for a bladed arb?
Old Feb 12, 2013 | 04:29 PM
andy escos's Avatar
andy escos
Mark from MK Motorsport can sell you the comp struts tca,s & a bladed roll bar set up which is top quality gear .
tca,s & comp struts
https://passionford.com/forum/trader...mp-struts.html
here is the roll bars
https://passionford.com/forum/trader...roll-bars.html
Old Feb 22, 2013 | 07:03 PM
ossie cossie's Avatar
ossie cossie
i may have to get some of these myself.
Old Feb 22, 2013 | 07:07 PM
ossie cossie
Gav, is that Lincoln,s 3 door with the bladed ARB?
Old Feb 22, 2013 | 09:18 PM
markk's Avatar
markk
drive it without and then make the decision whether you want or need it.
Old Feb 23, 2013 | 07:01 PM
MalZon's Avatar
MalZon
Yep, i gonna start with that..
Regards/Jonas
Old Feb 23, 2013 | 07:05 PM
dojj's Avatar
dojj
Resident Wrestling Legend
turbo techincs used to sell a comp strut and arb arb back in the way but the blaeded arb with drop links is the way to go
arb has to be front mounted though
Old Feb 28, 2013 | 02:18 PM
RS_Gav's Avatar
RS_Gav
This is Andreas 3dr from Sweden. One of the guys off Antilag.com.
Old Mar 15, 2013 | 04:39 PM
MalZon's Avatar
MalZon
It feels good when you drive on the street. Have not tried any advanced driving but after a wheel alignment is curvy roads strangely enjoyable to drive
I can adjust Toe in front and back, and the Caster in front. No Camber yet
Mvh Jonas
Old Mar 15, 2013 | 06:04 PM
markk's Avatar
markk
Ignoring the coloured boxes, the alignment figures look good, damper rate and springing dependant it should handle really nicely.
For years I never ran any roll bars at all, I could show you some pics on tarmac or how it turned in and it was not even set up for tar.
Old Mar 26, 2013 | 10:13 PM
Marc sierra
Just came across something that showed the setup on the Escort S1 and RS1600i. Apparently these have tie bars/compression struts and a separate arb as standard. The tie bar/compression strut goes through the tca, as the arb would do normally. And the arb is clamped to the compression strut.
I suppose this should also work on the Sierra setup, although you would need to be able to fit both the arb and compression strut to the arb mount on the chassis rail. But I've seen some brackets from Turbo Technics to do this.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
