Cossie Managed Fiesta RS Turbo Project
As some may have seen i was doing a cossie managed CVH turbo Mk2 Fiesta but that has been demoted to a daily as my mate offered me this Fiesta RS Turbo for £150 and i just couldnt say no lol
Mk2 thread HERE
I went up to my mates unit to put my Mk2 steels on it and get it ready to be moved to my mates garage where it will be stored untill he gets pissed off with it
The car is a rolling shell with alot of the bits required to put it back together im unsure at the moment exactly how much is missing, i know for a start it has no arches/skirts, windscreen, front seats, carpet, headlining and drivers door.
The shell is pretty clean and mostly in primer, it has new wings and rear quarters and a clean tailgate off an RS1800.
There is a gearbox and shafts etc in the car with bare bottom end bolted up and the full loom is still in the car fitted with a Clifford alarm.
Couple pics with the Mk2
I filled the Mk2 up with some of the bits i got with the RST shell
Heres some pics of the shell
I will do a post summarizing all the engine and managment bits i have to go in it from the Mk2 project thread
Mk2 thread HERE
Engine and managment bits i have for it so far
FRST EFi Charge Carrier
Modified EFi inlet with cossie throttle body, cossie sensors, fuel pipe, gaskets, FPR, Fuel rail
Modified MFi Charge Carrier
Blue Leads and Ignition Amp
Crank Pulley Setup
Cossie injectors, throttle cable and dizzy blanking cap
Wossner Pistons
PEC Conrods
ARP Conrod Bolts
ARP Head Stud and Nut Kit
ACL Bearings
Ferriday Thermal Inlet Gasket?
Standard RS Turbo Crank Machined For Above Parts
1.6 CVH Efi Block Machined For Above Parts
MFi Ported Cylinder Head with Newman PH4 Cam, Solid Lifters, Vernier Pulley
New water pump
Gaskets from Gaskets For Classics
Escort Cosworth P8 ECU
Bosch 803's
3 Bar Map Sensor
I will not be using the above MFi head, the lifters and Newman cam are going in an EFi head that i got with another FRST engine which i have now sold.
The EFi head is away at Oddkidd Creations at the moment getting some bits done and put together at the moment.
Crank Pulley Setup
Wossner Pistons
PEC Conrods
ARP Conrod Bolts
ACL Bearings
New water pump
Bosch 803's
3 Bar Map Sensor
Update
Been a while since i have updated but we have been pretty busy getting it ready for paint.
First of all massive thanks to zetec69 for his help, skills, knowledge, facilitys, tools, ideas etc stunning work bradders
There was a few bits i needed before it could go for paint so we piled in my mates passat and headed out to pick up a drivers door, spoiler, arches and skirts, windscreen and headlights. I thought it would all piss in the passat no worries but the door wasnt having any of it so i had to go all the way back there the next day in my Mk2 Fiesta to collect, it squeezed in.... just!
I also got another front bumper which has already been cut for a GRS cooler and im hoping to get lucky with clearance as i dont currently have a GRS cooler to mock up with lol
The main aim at this point was to get it ready to go for paint so we stripped it further leaving only the essencials underneith so it still rolled.
It turns out with closer inspection that the car has had alot of the hard work done with new wings, quarters, front panel and rear panel and the underside is clean and painted black so i wont be touching that at all yet.
Pics of it in the stripping stages
Then we removed all the mangled studs from the kit and spoiler and restudded them using adhesive and stainless bolts and drilled the arches to accept the kit and trial fitted.
With abit of digging the swage was re introduced on the bonnet
Then the painter picked the car up on his trailer and took the car to its new body shop home for the next 30 years or so lol
I also got my EFi head back from Jano at Oddkidd Creations after some machining and new parts with my newman ph4 cam and solid lifters fitted.
Good update mate, I was literally just about to get on your case to do it!
Much better with all that filler dug out of the bonnet swage line!
Should be a clean weapon when we're done, will look nice in my mirror
Need to get down to some hard work on the pile of parts now it's gone for paint.
Oh yeah, beware....got a text today saying my spoiler is ready to be collected. If he carries on working this fast your car will be done next week lmao
Brad
Brad
Haha side mirror as I'm ripping past you mean I take it?
Ill bring some boxes over and go through all that junk and sort out what needs a bit of work
Lets hope this uncaracteristic urgency is just a blip he must not be feeling well lol
Billy_RS
16
Oct 11, 2025 09:41 PM
