Comp ratio suggestions please
Old Jan 30, 2013 | 11:56 AM
ram's Avatar
ram
Has a large member
Default Comp ratio suggestions please
Hi guys
currently rebuilding my engine and need to send the pistons off for cut outs and possibly ratio change. my previous set up was running 7.5-1, but this was with C.P pistons, i'll now be running 4x4 Mahles.
spec will be..
200 block
2wd head with normal headgasket
standard rods
Mahle 4x4 pistons with cut outs
BD14
T38 around 30psi
Wondering if 7.5-1 is too low really? i have a feeling i once read that 4x4 pistons and 2wd head drops the ratio to 7.8-1 anyway? so if thats the case i guess i just go for pockets and leave ratio as it is.
Old Jan 30, 2013 | 12:04 PM
Bart's Avatar
Bart
I would do just cut outs and keep the c/r as high as possible.
Old Jan 30, 2013 | 11:51 PM
ram's Avatar
ram
Has a large member
Thanks yeh so long as the ratio is 7.8-1 with my head and piston set up then i'll leave the skimming. just need someone to confirm that really
Prickly_buzz
Dec 7, 2017 09:52 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Chas
Oct 5, 2015 07:13 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
Si B
Sep 12, 2015 06:49 AM
