Fiesta MK7 S1600 & METAL Editions These 2 models of Ford's Mk7 Fiesta were made in limited numbers of around a 1000 of each, fast becoming rare
zetec sigma phase 1 an 2
Old Jan 29, 2013 | 08:42 PM
rallyesport04's Avatar
rallyesport04
Default zetec sigma phase 1 an 2
whats the differance between the sigma phase 1 an phase 2 ive heard the phase 2 is better but found no reason why its better theres no visual differance apart from the rocker cover i assume the internals are better anyone know the answer
Old Jan 29, 2013 | 09:04 PM
Straight_4_N/a's Avatar
Straight_4_N/a
iirc Theres very little to no diffrance between them and the bit about people saying the phase 2 is stonger than the phase 1 is just a myth, there both weak and gutless engines.
Old Jan 30, 2013 | 04:50 PM
rallyesport04
personaly i found them to be quite reliable in standard form an i know of two 1.4's pushing 165 horse an been reliable on the rally stages the drive shafts have been the weakness but saying that i assume the rods pistons aint stock
Old Jan 30, 2013 | 05:08 PM
martysmartie's Avatar
martysmartie
They can't be that bad as they are very popular in rally cars, the bottom ends are known to let go but then thats due to bad maintenance!
Back to the question there are differences in the valve train, this is no difference in power etc.
Martin
Old Jan 31, 2013 | 05:26 PM
rallyesport04
thats what im trying to find out what the differances are an pick the best bits to make something half decent without paying silly money cos if it goes pop nip down the breakers yard an come home with another for under 200 notes thrash that till it breaks an so on
Old Feb 1, 2013 | 12:40 PM
martysmartie
Like I say, none, there is a difference in the valves between the two, but that is to do with the design rather than strength.
Martin
Old Feb 1, 2013 | 04:54 PM
rallyesport04
ok makes sence as shawspeed say with phase 1 you need blanks an phase 2 you can use regrinds or blanks somthing to do with the shiming on phase 1 is the issue oh well i will stick with what i got then cheers
Old Nov 16, 2018 | 07:56 AM
Kristina Clover's Avatar
Kristina Clover
Hi there, this is slightly off topic, but I wondered if you zetec has power steering - it’s just that I have a Fiesta 3.5 with power steering and having problems locating a spare steering nuckle and wondered if the zetec might have an interchangeable nuckle with the 3.5 fiesta. Thanks
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
