Fiesta 06 plate zetec
Old Jan 29, 2013 | 08:21 PM
creator's Avatar
creator
Default Fiesta 06 plate zetec
Hi chaps just a quick one got to change a front coil sping on an 06 plate fiesta think its a 1.4 zetec.not see the car yet but what size is the lock nut on the shocker? And does a normal socket fit n or do i need a cranked spanner?
Old Jan 29, 2013 | 08:35 PM
studabear's Avatar
studabear
you don't touch the hub nut
pinch bolt for shocker to hub is 18mm 0r 19mm
anti roll bar link is a 15mm, need a 17mm open ended spanner to stop it spinning
brake hose is attached via clip
top mount is 3x13mm nuts
when springs compressed its a 18mm nut down the recess, 6mm allen key in shock piston.
drivers side is normally full of water and rusty as fuck so the shocker nut is a pain to undo
Old Jan 29, 2013 | 08:42 PM
creator's Avatar
creator
Cheers for that stu mate i ment the ahocker nut on the top mount bearing not the hib nut cheers for the answer tho mate cant be bothered with a load of tools at the side of the road lol
Old Jan 29, 2013 | 09:02 PM
studabear's Avatar
studabear
the spring is a concaved/curved type when uncompressed so be extra carefull when compressing it, I find a short 18mm impact socket with vice grips clamped to it easiest for undoing the top nut, so you can keep the shocker piston still using a allen key socket and ratchet/bar, even then they can be a pain.
Old Jan 29, 2013 | 09:26 PM
creator's Avatar
creator
Cheers stu got my big snap on impact gun so hopefully that should smash it off
rex647
Mar 6, 2022 06:20 AM
28
Sep 8, 2015 07:10 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
BRAM
Sep 8, 2015 07:11 AM
