Larger Calipers?
Old Jan 29, 2013 | 06:36 PM
Sausage's Avatar
Sausage
Default Larger Calipers?
Would running a larger caliper on the same size disc make much of a difference?
Was thinking of swapping to a caliper with twic the pad area but don't want to waste money if i won't get much benefit.
Cheers.
Old Jan 29, 2013 | 07:36 PM
dojj's Avatar
dojj
Resident Wrestling Legend
larger calipers won't fit unless you get longer ones which will give more pressure on more of the disc
much easier way is to use the same caliper but insert a larger disc so you get more leverage and stop better
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
