Okay so lets assume an alignment is already done but at the track you decide you need to make a camber adjustment on the fly. How much do you lengthen/shorten to gain or remove a 1/2 a degree? (say thread pitch is 1mm, that means 1 full turn makes tca 2mm longer. How does that translate to camber?).
