07 Transit, piston 4 lost compression - how best to resolve?
2Evos & 1 Escort Van :-)
A friend of mine has just bought a nice 07 plate transit from eBay. It has a 2009 140 bhp TD lump, ECU and 6 speed box conversion.
It was sold due to the engine being knackered. According to the seller it has no compression on no 4. The engine is believed to have only done 40000 miles
What sort of thing might cause this and what will be the easiest way to get it running?
Is a new lump cheaper / less hassle than getting this one rebuilt?
Anyone got a motor they want to sell
I build those puma engines everyday, I'd say it's easy to rebuilt but I guess I'm biased. Ford don't make it easy to get hold of engine components either. You got any way of pressurising the cylinder to see where the compression is going? Eg whip an injector out, wedge an airline in there tight ( at tdc obviously so it don't turn over) listen for escape into te inlet, exhaust or oil filler cap?
That'll tell you whether it's bottom end or valve train
Thanks for the replies folks
My friend got the van home today, so not sure what the actual score with the motor is yet.
From reading the above, seems injectors might be an issue.
Will report back as soon as I get a chance to speak to him to see what he finds.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
deathrider666
Sep 28, 2015 06:12 PM
