Wheels and Tyres Wheels and Tyres for all Ford's
19's on transit connect
Old Jan 28, 2013 | 06:51 PM
Big Ron's Avatar
Big Ron
Default 19's on transit connect
Will the standard wheels from a Mk2 Focus RS fit on a transit connect??
Thanks in advance
Old Jan 28, 2013 | 06:59 PM
RichieST's Avatar
RichieST
They should go on but you might need spacers as they have a very high offset so you might find they will catch the strut. Use 15mm hubcentric spacers with the RS wheels on my ST
Old Jan 28, 2013 | 09:16 PM
neil117's Avatar
neil117
part of the bonus crew!!!
Yes there's one runs about dunfermline
Old Jan 29, 2013 | 04:18 AM
Get them fitted and see if they are ok and dont catch.
Old Jan 29, 2013 | 06:10 AM
T28 RST's Avatar
T28 RST
Ok then
Will look awesome
Old Jan 29, 2013 | 09:20 AM
Big Ron's Avatar
Big Ron
Cheers lads, off to the garage i go!! Will keep you posted!
Old Jan 29, 2013 | 09:30 AM
RichieST's Avatar
RichieST
Post some pics when they're on
Old Feb 2, 2013 | 07:39 AM
Big Ron's Avatar
Big Ron
Will do, gonna get the machine polisher out first so i don't embarass myself!!
Old Feb 7, 2013 | 03:30 PM
Big Ron's Avatar
Big Ron
They catch! Well the front hit the strut
Spacers it is!
Old Feb 7, 2013 | 03:54 PM
RichieST's Avatar
RichieST
Thought they would! I've got 15mm eibach hubcentric spacers on my ST, cures any clearance issues. You just need to be careful if you are using standard ford locking wheel nuts with them as the studs are too long so it will cause the locking nut not to wind all the way down, so it can crack the nut. The cure is to either lop off a couple of threads off the end of one of the studs or do what I did and get some mcgard locking nuts. If you want to know the right part number for them I'll have a look through my paperwork to find it for you.
Old Feb 7, 2013 | 07:22 PM
peter/jedi's Avatar
peter/jedi
My mates got a set on his and they seem to be ok
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
stevecfrst1
Sep 30, 2015 05:18 AM
