iphone to Radio connection on ST-2 08 plate
Old Jan 27, 2013 | 06:51 PM
st3v3's Avatar
st3v3
Default iphone to Radio connection on ST-2 08 plate
Can any one point me in the right direction of what cable i would need to connect my iphone to my radio in my ST-2 on an 08 plate?
From what the dealer told me, yet couldnt point me in the right direction, the Aux input for this is in the Glove compartment.
Thanks
Old Jan 27, 2013 | 06:53 PM
RichieST's Avatar
RichieST
the aux connection is right at the front of the glove box along the top edge, big grey socket if it has one!
Old Jan 27, 2013 | 06:54 PM
RichieST's Avatar
RichieST
and you will need a normal 3.5mm at each end cable to plug your iphone in to it unless you want to get an aftermarket ipod controller thing for it!
Old Jan 27, 2013 | 07:07 PM
st3v3's Avatar
st3v3
It does.
So basicaly, if im reading you right here, i will need a 3.5mm jack on each end, i plug one end into the Aux in the glove box input and the other into my iphone headphone jack and simply play the music via the radio as if it was infact a big set of headphones?
Is it really that simple?
Old Jan 27, 2013 | 07:37 PM
RichieST's Avatar
RichieST
that's right!
Old Jan 27, 2013 | 07:46 PM
st3v3's Avatar
st3v3
that's right!
Thanks for your help,cable ordered and on its way
Rep sent
Old Feb 2, 2013 | 10:01 AM
thebigmacmoomin's Avatar
thebigmacmoomin
I also use an FM transmittor that plugs into the bottom of the iphone, the charger socket. You set it to an FM frequency, say 95.5FM then tune your car radio to that frequency and you can listen to your music that way. No need for wires everywhere.
Old Feb 2, 2013 | 10:54 AM
RichieST's Avatar
RichieST
Problem is with those fm transmittors is the sound quality is awful!
bobsworth
77
Mar 24, 2016 09:30 PM
Mark RS
Oct 12, 2015 06:01 AM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
stevecfrst1
Sep 30, 2015 05:18 AM
