Performance engine bits
Forge actuator for Focus RS GT2560 and hybrids with yellow spring (for use with electronic boost control)
£70 posted
Bailey recirculating dump valve, just like Forge 007 or 008. 25mm connections £40 posted
Owen Developments turbo jacket. Increased spool and reduced temps, very impressed with it tbh. £80 posted
http://www.rsownersclub.co.uk/rsocbb...d.php?t=215379
£70 posted
Manifold sold, Forge actuator and Area Six cam still available.
Spec of the cam is 262 deg. and 10.4mm lift. As for timing instructions this is what Ian recommended.
"I normally measure lift at TDC during opening. Start with 0.5mm lift(at the follower) and test drive it. You may want to retard the cam (less lift at tdc) if you want it to hang on more at the top end, but trial and testing will give you the answer
Good luck
Ian
www.area-six.co.uk
01522 877887"
Good luck
Ian
www.area-six.co.uk
01522 877887"
JoeyBoyden
Jan 4, 2024 02:36 PM
rog
Sep 4, 2015 12:10 PM
