Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
rear brake problem
Old Jan 27, 2013 | 07:28 AM
rick denny's Avatar
rick denny
Pontiac drag racer
Default rear brake problem
just put new calipers on my 2003 Zetec Focus. if I hook both handbrake cables up, the left side rear disc gets really hot after driving a short distance. if I unhook just 1 cable on either side it doesn`t do it.
the handbrake is definitely releasing as I can see the lever on the back of the caliper going all the way back to the stop.
any ideas?
Old Jan 27, 2013 | 07:41 AM
RichieST's Avatar
RichieST
Sounds like they need adjusting up. Take off the leather trim around the handbrake lever, you will see a nut on the side of the lever on the end of the cable. Make sure this is unwound and hasn't been tightened right down. Then there should be an adjuster for each caliper further along the cable, underneath the car somewhere!
Old Jan 27, 2013 | 08:19 AM
shalon's Avatar
shalon
are the cables seized there bad for corroding inside and making cable tight is the caliper piston adjusted properly
Old Jan 27, 2013 | 08:32 AM
cossiejay's Avatar
cossiejay
id go will adjusting the cable sound like it has benn done up at some point to compensate for worn pads ,more then likely just needs readjusting
Old Jan 27, 2013 | 11:00 AM
rick denny's Avatar
rick denny
Pontiac drag racer
The nut is loosened right off at the adjuster on the hand brake itself. as it is now, there is no tension on the cables at the caliper end at all. I don`t see any adjusters under the car and discs spin freely until it gets driven.
original
Apr 28, 2026 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
