Main service of Cosworth. Parts and places.
Old Jan 26, 2013 | 11:36 AM
Rossy43's Avatar
Rossy43
Fiesta ZS. FF feat nov'11
Default Main service of Cosworth. Parts and places.
I bought my 3 door Cosworth in January 2012 and before putting it on the road i changed the oil and filter etc. now its been off the road since september and will be back out in april. Since i dont know for sure whats been done previous i'd like to do a big/main service. What im asking is what should be done?
Also if you could list parts and where is best to get um. Hopefully Matt Lewis will stock most of them. I dont need advise on oil as I already use mobil1 10/60 and im happy with that.
Cheers again.
Old Jan 26, 2013 | 11:52 AM
saph4be's Avatar
saph4be
plugs air filter and cambelt, for a start!
Old Jan 26, 2013 | 11:59 AM
Rossy43's Avatar
Rossy43
Cambelt got done in august down Turbosystems.
What plugs would you recommend. Ive seen an array of opinions.
Old Jan 26, 2013 | 12:18 PM
1374lee's Avatar
1374lee
I would do the fuel filter aswell.As for plugs,it's all dependant on the spec of your engine.
Thanks.Lee.
Old Jan 26, 2013 | 12:31 PM
Rossy43's Avatar
Rossy43
Its t.35.55/55's/livemap. 380-400.
So far ive got..
Oil
Oil filter
Fuel filter
Plugs
Air filter is group A so will just want a clean and cambelt just done.
Old Jan 26, 2013 | 01:12 PM
Rsmat's Avatar
Rsmat
Plugs...ford 071's are fine.... Matt Lewis
Fuel filter ... matt Lewis
Oil filter ... Matt Lewis
Oil ... You have your own
That's all would change is it ran fine before and it's had a cam belt change .
Old Jan 26, 2013 | 05:22 PM
Gary F's Avatar
Gary F
Ross make sure you gap the plugs.
Old Jan 27, 2013 | 03:03 PM
Rossy43's Avatar
Rossy43
Thanks lads.
Gary what would you recommend gapping the plugs too? If we say its running 30-32psi?
Old Jan 27, 2013 | 03:46 PM
martysmartie's Avatar
martysmartie
Originally Posted by Rossy43
Thanks lads.
If still on standard ignition system, very small, around .6MM.
Also no one has mentioned coolant, it depends when it was last changed, unless you know I would change it.
Martin
Old Jan 27, 2013 | 03:58 PM
Gary F's Avatar
Gary F
Ross just see what Tony's gapped your current plugs too.
Old Jan 27, 2013 | 04:01 PM
Rossy43's Avatar
Rossy43
Its got a grpA coil, and coolant is a good one I didnt think of.
Yeah Gary i think i will just do that mate.
Old Jan 27, 2013 | 05:12 PM
BRAMMER's Avatar
BRAMMER
If it hasn't already I would replace the fuel and fan wiring
Old Jan 27, 2013 | 07:55 PM
Rossy43's Avatar
Rossy43
Fuel is done.
Fan is on order from Matt. Thanks.
Old Jan 27, 2013 | 08:11 PM
m11rcm's Avatar
m11rcm
Change the gearbox and diff oils.
Old Jan 27, 2013 | 08:38 PM
1374lee's Avatar
1374lee
As above .6m on standard ignition system.Brake fluid may need changing and bleeding through the system if not already done,just a thought.
Another thing check the condition of your auxillary belts if not already done.
Thanks.Lee.
Old Jan 27, 2013 | 08:47 PM
Rossy43's Avatar
Rossy43
Thanks alot for everyones input.
Ive sored most of the things wirh Matt, but the mention of belts has reminded me i need those.
Old Jan 28, 2013 | 05:55 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Have the oils if needed Ross aswell
Old Jan 28, 2013 | 08:00 PM
Rossy43's Avatar
Rossy43
No problem. May well add those to the list aswell Matt.
Old Jan 28, 2013 | 11:21 PM
Rax's Avatar
Rax
Standard ignition ? dizzy cap and rotor arm.No one has mentioned that.First thing I did with mine was cap,r/arm ,f filter,oil&filter,plugs leads,coolent and clean air filter.For the price of the cps etc I would change them all.Well if I was in this situation again.Oh and a good clean of the throttle body.
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
