Ford Racing Puma 481 (S1700 Engine Finished)
Old Jan 23, 2013 | 06:09 PM
Ryan G's Avatar
Ryan G
Default Ford Racing Puma 481 (S1700 Engine Finished)
Hi fellas thought id give you the low down on whats planned for my frp. Ill get to the exciting bits shortly, but for now ill start with when i got it.
The car is frp 481, i took a 4 hour drive to collect it and it was the first i viewed. Unfortunately the car had a suspected gearbox problem along with a bunch of other niggly bits im going to have to get done.
I bought a frp gearbox to replace mine, but after a semi mot check over i found a broken driveshaft cv joint. To say i was excited was an understatement! I replaced the broken joint and for good measurement replaced the wheel bearing, the other side bearing will be getting done shortly as its in for some track/nurburgring abuse!!
This was the cure to my problems! I drove the car for the first time last weekend and love it, its such a possitive driving experience and cant wait to get on track. But, before i do theres a couple of bits i need to sort. Firstly the steering wheel, the badly worn alcantara original was driving me mental, so i was straight onto demon theives for a 350mm sparco suede wheel and boss kit. It looks and feels soooo much better! Secondly, being 6 foot 6 tall the seat was a touch close, so with a 70mm extended seat rail im at home.
Lastly for now is the splitter, the car didnt come with one so i purchased one from puma build and is now fitted.
For now that is all, but ill give you the rest of my plans.
The gearbox i bought as a replacement i am rebuilding with a rs turbo limited slip diff, ready for my engine.
Brakes wise i will be removing the alcons and replacing with my 4 pot 330mm ap racing brakes. I use ds2500 pads as i love the compromise of great bite on the road with no fading being a light car on track.
Gaz coilovers will be fitted along with raceline rl7s
The engine, now this is for the longterm but im in the right workplace to get me my goals.
I work with my dad Harvey Gibbs who develped not only the racing puma engine but the works s1600 puma engine.
After many discussions we have devised a plan.
I have a donor 1700cc puma engine, The head will be visiting nick waples for a full blown port rework and valve/insert size upgrade.
The cams i already have and are circa 12.5mm lift inlet 290ish deg duration and exh 12mm lift and 270 deg duration.
It will have one off cp pistons and rod configuration with a compression ratio between 12 and 13:1
The bottom end will be balanced and put together by myself and my dad.
I plan on running 44mm spindless throttle bodies and a super 1600 genuine exhaust manifold and system.
We aim for 240bhp at 9000rpm.
The car will be painted and off to shows, trackdays and ring trips
I will eventually get a build thread up with a picture progress report.
Sorry to waffel on i hope you enjoy reading my plans
Thanks, Ryan
Old Jan 23, 2013 | 06:29 PM
Ryan G's Avatar
Ryan G
Fitted my rl7s and ap racing 330mm 4pots.
Escos Gaz from durham painted it and looks amazing but havnt had chance to give it a proper clean yet.
Decided the underneath neaded a freshen up so stripped it back and stone chip the underside and arches black.
Old Jan 23, 2013 | 06:40 PM
dingla rs's Avatar
dingla rs
looks like you have some nice toys mate an I don't just mean the cars looks great
Old Jan 23, 2013 | 07:02 PM
J1mbo's Avatar
J1mbo
B1mbo
Not too bad rybo
Old Jan 23, 2013 | 07:32 PM
RSRick3290's Avatar
RSRick3290
Looks good
Old Jan 23, 2013 | 08:02 PM
Sticky.'s Avatar
Sticky.
Great cars the Racing Puma, I like the RL's but looked better on the old style comps.
Look even better if the shonky Sierra wasn't next to it......
Keep the updates coming
Old Jan 23, 2013 | 08:13 PM
georgie1's Avatar
georgie1
what car they off to fit a puma m8
Old Jan 23, 2013 | 08:15 PM
Daveybob77's Avatar
Daveybob77
Love the FRP's! Looks like a good project you've got there mate
Old Jan 23, 2013 | 08:18 PM
Ryan G's Avatar
Ryan G
Cheers guys hope you like it
Old Jan 23, 2013 | 08:19 PM
Ryan G's Avatar
Ryan G
They were 2wd cossie fitment which we made fit
Old Jan 23, 2013 | 08:25 PM
Ryan G's Avatar
Ryan G
Yer there brilliant fun to drive.
Yes i loved the old style comps but made the gearing too high, it is geared for 160mph at 9000rpm on 17's. would be way too much on 18's unfortunately
As much as i like to abuse my brother i have to admit his saphire is the nicest ive seen
Old Jan 23, 2013 | 08:39 PM
maxest's Avatar
maxest
Cool project look forward to seeing it progress
Old Jan 23, 2013 | 09:05 PM
M16NTE's Avatar
M16NTE
ryan its looking lovely mate, i sure wouldnt mind one of those for a daily.. keep at it chap..
Old Jan 23, 2013 | 09:15 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Looks very nice!
As for your cams, the SE tuning guide in Fast Ford a couple of months back said the maximum liftyou can physically achieve is 10.3mm inlet and 9.65mm exhaust, how are you going to get 12.5mm?!
Old Jan 23, 2013 | 09:19 PM
Ryan G's Avatar
Ryan G
Cheers max.
Thanks gary its my daily and every time i drive it i just have the biggest grin on my face, id choose it over just about any other car ive driven
Old Jan 23, 2013 | 09:21 PM
Ryan G's Avatar
Ryan G
Originally Posted by CrOwSoN15
Looks very nice!
I have genuine s1600 development cams that fit in with no head mods, i would say they mean thats the max with standard valve springs and no pockets in the pistons
Old Jan 24, 2013 | 12:10 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Really like the frp . Will be keeping aneye on the build
Old Jan 25, 2013 | 08:04 PM
I love these cars.Im.thinking about going to see Gaz about my saffs body work.Is he good then.
Old Jan 25, 2013 | 09:54 PM
Ryan G's Avatar
Ryan G
Yer he is bloody brilliant he done mine and jims saph and they both are amazing
Old Jan 28, 2013 | 05:22 AM
How much did he charge if you dont mind me asking.
Old Jan 28, 2013 | 12:36 PM
Ryan G's Avatar
Ryan G
Pm'd
Old Jan 28, 2013 | 02:17 PM
Read your pm and replyed bud.
Old Jan 28, 2013 | 07:53 PM
slammed106's Avatar
slammed106
like i said saturday, it looks lovely Ry... nice to have rare ford too, not like that mass produced saff your bro`s got hahaha
i do still think it needs to sit lower and the wheels spaced out (they`re some hoofin gurt arches to fill!!) but have o doubt you`ll sort it....
so when does my shonky renault get a shot at it?????? hahahahaha
Old Jan 28, 2013 | 08:04 PM
Ryan G's Avatar
Ryan G
Haha, yep im getting some coilovers soon thinking of gaz golds as the standard ones corrode really bad, the front wheels are staying as is as dont want to mess up the awesome geomentry but the backs are being spaced 10mm.
As for the renault you have a few more ponies than i do, for now, so there best be a few corners lol
Old Jan 28, 2013 | 08:26 PM
slammed106's Avatar
slammed106
hahahaha sounds good!.. just need the tarmac to dry out as tbh, i`m struggling with the mega camber up front!
looking forward to seeing (and hearing) the NA build...
whats the deal with the spindleless bodies?? are they roller barrels like the duratec/cosworth items or where the butterfly becomes the spindle like the AT power items????
Old Jan 28, 2013 | 08:31 PM
Ryan G's Avatar
Ryan G
Does yours run more camber than standard?
Yer will sound awesome at 9k
The ones i thought about using were the at power ones but found some 45mm x 38mm barrel throttles which i may use yet failing that we knowa lad at titan so may have a set of there barrels, too many choices just gotta get saving
Old Jan 28, 2013 | 08:41 PM
slammed106's Avatar
slammed106
i cant remember the numbers but 2mm toe out and 2.5deg on the front i think....
barrels are the way to go if you have room.. Matts got a set of TITANs in the office @ TDF.. they`re a very nice little bit of kit..
if its an area you want to keep to yourself just say, but whats your thoughts on inlet length/injector position (4 or 8??) on the NA build.. i know from personal experience with the pug its an area that can massively affect outputs.. even down to trumpet length/taper... i would have a guess at around 325mm valve face to trumpet top???
Old Jan 28, 2013 | 08:53 PM
J1mbo's Avatar
J1mbo
B1mbo
I will answer this one, he dosnt know
The ideal legnth however will be different to the supper 1600 so will be optimised on the dyno I would imagine he will use the s1600 set up as a base to start from.
For outright power 8injector is the way to go.
Run banked injection and turn the back set on around 6ms injector on time (or there abouts), this way you can run the front set to a reasonably high power output with best drivability and switch backs on for power.
Whilst on the dyno he can see at what rpm he gets stand off (if it does) and switch the fronts on more than the rear.
(6r4 was the perfect example for the standoff issue)
Old Jan 28, 2013 | 09:00 PM
J1mbo's Avatar
J1mbo
B1mbo
Ps 325mm/13inches is massively long
Circa 7-8inches is where the s1600s ran.
Also trumpet radius is key you need 45 degrees anything over, even to 180 degree radius makes no difference
Old Jan 28, 2013 | 09:03 PM
slammed106's Avatar
slammed106
hahaha
and i thought you were just a boost boy jim with the attitude of "pass me an 11mm spanner and some molegrips" to get power!!!!!
so you`ll run injectors nearer the valve for lower down the revs and bring in a set higher up the tract as the revs increase (and give more time to mix the air/fuel)??
Old Jan 28, 2013 | 09:09 PM
J1mbo's Avatar
J1mbo
B1mbo
I have love for NA engines And a nerdy brother who half knows his shit lol
Yes thats the idea. Injectors in the back of the trumpet pick up big power gains over on the back of the valve.
Old Jan 28, 2013 | 09:15 PM
slammed106's Avatar
slammed106
hahahaha
dont mess with the denim assassin!!!
so where will they live in this engine?? 1 in the T/B and 1 in the trumpet?? or is there a location in the head? (i never had a good look at the engine when phil had it, just dragged it around his patio)
Old Jan 28, 2013 | 09:22 PM
J1mbo's Avatar
J1mbo
B1mbo
That I'm not sure half of it depends on fitment to car, ideally one in the start of the bodies and one at the back, realistically though it will be both in the bodie at two distances apart
J1mbo's Avatar
J1mbo
B1mbo
Rybo in my ear says there is one in the head on the valve and then use four in the bodies
Old Jan 28, 2013 | 09:23 PM
Ryan G's Avatar
Ryan G
Bearing in mind my engine has vvt so you gain alot over a standard engine anyway so these injector positions and trumpet length dont have to be spot on optimised, the vvt gives you the drivability and tourque down the bottom that you would normally lose with having inlet tracks and injector position tuned for top end power. You have to come to a compromise as mines being a road and track engine and thats what the vvt allows.
You can sit the engine at 9000 rpm and with the touch of a button advance and retard the cam timing watching it pick up power
Old Jan 28, 2013 | 09:47 PM
slammed106's Avatar
slammed106
Will have to have a looky at this when you start building it up...
Old May 9, 2013 | 09:57 PM
Ryan G's Avatar
Ryan G
Whoops haven't updated in ages, alots been going on and its coming along nicely now
Block all cleaned and painted
New larger valves
Bit of difference to standard cams lol
S1600 valve-train
Cad drawing from titan motorsport for itb's
Lightened flywheel thanks to Mark Walker
Pistons and rods
Custom inlet from titan to our spec
The car looking lovely ready for the new engine
Just waiting on crank which is being knife edged and balanced.
Cylinder head is with nick waples where he is working his magic
Old May 9, 2013 | 10:00 PM
m4tt274's Avatar
m4tt274
I hope you didnt just paint on top of all that rust! :O
Rest of it looks cracking though, lovely car, i would love one!
Old May 9, 2013 | 10:05 PM
Ryan G's Avatar
Ryan G
Haha dont worry its not paint and no it didnt go straight on like that, i skipped alot of pictures, just posted before and after to save boring people
Thanks
Old May 10, 2013 | 07:36 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Looking good now mate, those cams look mental in comparison to the originals
