turbo hanger cosworth
Old Jan 22, 2013 | 09:21 PM
paddy heffernan's Avatar
paddy heffernan
heffo
Default turbo hanger cosworth
i lost bolt out of turbo hanger the bolt goes down through ganger into head .i dont know if theres also a sleeve around bolt or if bolt is heavier on the shaft and smaller at threaded section as threaded part is 8mm but hole in hanger is about 18 mm .anyone able to tell me .thanks in advance.
Old Jan 23, 2013 | 12:25 PM
TOMMY_TURBO's Avatar
TOMMY_TURBO
no help but i need same thing
Old Jan 23, 2013 | 05:38 PM
tosh's Avatar
tosh
I think from memory it's just the bolt and a thick washer the reason the hole is larger than the bolt is to allow you to move the hanger around to get the right adjustment/spacing.
Old Jan 23, 2013 | 10:03 PM
TOMMY_TURBO
thats what i was told but see this on ebay
http://www.ebay.co.uk/itm/FORD-SIERR...vip=true&rt=nc
Old Jan 23, 2013 | 10:27 PM
paddy heffernan
heffo
Default turbo
thanks guys looks like ive lost bush aswell .
Old Jan 24, 2013 | 09:14 AM
tosh's Avatar
tosh
That rubber bush in that eBay advert is a bit strange I can't see how that would work?
I just had a look in the workshop manual and it just shows as I mentioned above just the bolt and thick washer bolts through the hanger block onto the head.
Old Jan 24, 2013 | 09:16 AM
TOMMY_TURBO
yh i was told it only has a washer by a few people som1 must have made that bush thing
Matt Baxter
Sep 16, 2015 08:30 PM
cameron2
Aug 19, 2015 11:49 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
cameron2
Aug 10, 2015 12:14 PM
