Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Brake Lines Help Needed
Old Jan 22, 2013 | 08:54 PM
Straight_4_N/a's Avatar
Straight_4_N/a
Default Brake Lines Help Needed
As aboveive currently got braided brake lines for my std caiplers (st170 caiplers) but im going to upgrade to high spec 4 pot caiplers and i dont really see why i should spend £700 on the kit from them when it only costs me £300ish for just the caiplers and brackets as im using the same size disc, Now the problem ive got is my current lines wont fit the 4 pots as thay have a diffrent type of fitting,
So my question is are there any fitments out there that i can fit onto my current brake lines to make them match the ones needed for the caiplers?
Or could i just cut the ends off my curent lines and fit these?
http://www.rallydesign.co.uk/product...oducts_id=1534
I know im sounding like a cheap git but i was just wondering where its just a smiple £6 fix or £130 for new brake lines :/
Old Jan 22, 2013 | 09:35 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
is this for your fiesta?? are the 170s not good enough then?
Old Jan 22, 2013 | 10:08 PM
Straight_4_N/a
Yeap, Nope where near good enough for me and i could easly out brake you and ajc lmao. Then again nervs said i was using to big brakes on the focus and im going bigger on a much smaller lighter car lmao.
Old Jan 23, 2013 | 08:55 AM
The Underdog
you cant fix stupid
if you drove my car on the day you would have been shocked how bad they were. pedal was soft as a sponge.ruined them.
Old Mar 25, 2013 | 06:47 PM
Jdevaney89's Avatar
Jdevaney89
Dont cut the lines, thats bodging and dangerous, the ends are machine pressed for a reason, to stop leaks. Get the correct cable and fitment from ebay/breakers, FSP (Ford spare parts, google it) are pretty good for things like this.
original
Apr 28, 2026 05:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
c20tbo
Aug 17, 2015 10:19 PM
Red_bull
Aug 9, 2015 08:34 AM
Bosch
Aug 4, 2015 05:14 PM
