T34 -Black Siemens
Brand new Siemens Dekas for sale. Flow matched to within 1%.
Spec:
80LB / 875CC FLOW RATE
Body Design: Pencil, composite plastic
Flow rates:
825cc/min, 80lbs/hr at 43.5 psi (3 bar)
915cc/min, 88lbs/hr at 50 psi (3.5 bar)
980cc/min, 94.5lbs/hr at 58 psi (4 bar)
Dynamic Flow Rate : 18.6 mg/pulse 2.5ms PW, 20 ms Period
(This injector will work with all factory injector drivers)
Length: 3 inches, 74 mm
Diameter: 19 mm
SET OF 4 210£ posted
Spec:
Flow rates:
Diameter: 19 mm
Russ Payne
Sep 25, 2015 08:29 PM
