Engine rebuild , on going
Old Jan 19, 2013 | 11:25 AM
cossie daz's Avatar
cossie daz
Default Engine rebuild , on going
Hi all ,
Would a 2wd or 4x4 head make a difference on a high power engine ?
I'm rebuilding my engine as it tired but have a 4x4 head on engine in car but got a 2wd head in loft
Going to send a head off is there any difference between the 2 heads ?
To cut a long story short , which head better for porting ?
Old Jan 19, 2013 | 04:48 PM
matthewpickup's Avatar
matthewpickup
4x4 i think ?
Old Jan 19, 2013 | 08:27 PM
cossie daz's Avatar
cossie daz
Anyone else ?
Old Jan 19, 2013 | 09:00 PM
dissmalrs's Avatar
dissmalrs
As far as I can see the main difference us the combustion chamber shape its smaller on a 4x4. And the temp sender is in a deferent place but as far as porting is concerned you can poet them the same
Although I will add that there has to be a reason for the change in combustion chamber shape on the 4x4 one
Manu because the transfer to unleaded or the emotions
Also as far as I can find out the 4x4 head has better cooling and oil feed to the turbo
Old Jan 20, 2013 | 01:29 AM
Paul500+'s Avatar
Paul500+
talk to an engine builder m8, im using joe @ blue sprint but theres plenty out there
Old Jan 20, 2013 | 09:38 AM
cossie daz's Avatar
cossie daz
Thanks peeps
Old Jan 20, 2013 | 10:22 AM
siscossie's Avatar
siscossie
3-door moonstone
I put a 4wd head on my 2wd block with a slight port made a big difference
Rstar_man
143
Jul 20, 2020 11:16 PM
Wilsfoci
15
Mar 30, 2016 10:26 PM
cossiedean84
37
Sep 2, 2015 10:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
