Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Fiesta 2000 - Radio Installation
Old Jan 17, 2013 | 05:43 PM
wayne_collins's Avatar
wayne_collins
Default Fiesta 2000 - Radio Installation
Hi Guys,
I have a factory fitted radio in my car currently but it has had it's days.
I have purchase a Pioneer DEH-1320 and A Fascia for the car. The fascia came with a clip which I have worked out by looking at the radio currently in my car that this clip must attach to the unit and that is how it slides into the car and is held in place (to prevent it falling)...
I have attached a picture of the back of the stereo unit and the clip. How the hell do I attach these together.... I have no screws.
All help is appreciated.
Old Jan 17, 2013 | 06:16 PM
STeve's Avatar
Super Moderator
the radio should have came with the mounting bolt as the radio is showing the hole the bracket to mount to just right of the wiring plug, most just chuck it away
Old Jan 17, 2013 | 06:25 PM
wayne_collins
The radio came with nothing else.. it was all boxed but no mounting bolts..
Old Jan 17, 2013 | 08:24 PM
STeve's Avatar
Super Moderator
suggest you contact whoever you bought it from as they are normally with the removal keys in the box or pop into a audio shop as it will cost pence
Old Jan 17, 2013 | 08:33 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Aslong as the radio's got a cage it slots in to it wont fall once its pushed in tight, wouldn't worry about the plastic bit!
Old Jan 17, 2013 | 09:12 PM
wayne_collins
But the only thing holding it in place would be the plastic fascia?
Old Jan 17, 2013 | 09:26 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Put the cage into the fascia, bend the tabs at the top and bottom so it locks into place, then slide radio into cage. Cage is designed to be a tight fit to the radio so wont just fall out its hole as long as you install in properly.
Old Jan 18, 2013 | 11:12 AM
STeve's Avatar
Super Moderator
on fiesta's they drop without the plastic support as it has happened to me before and for the sake of a few pence you may as well do it right
Old Jan 18, 2013 | 09:03 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Ah never fitted one on a Fiesta before! Maybe Maplin will sell them?
Old Jan 18, 2013 | 09:18 PM
STeve's Avatar
Super Moderator
was in halfords today and they had them and if he gives them a sob story chances are he will get it for free
gambo08
Feb 4, 2016 10:49 PM
Steve Escos
Oct 1, 2015 06:57 AM
little bram
Sep 27, 2015 07:45 AM
