Wheels and Tyres Wheels and Tyres for all Ford's
Is this Tyre Legal?
Old Jan 17, 2013 | 05:25 PM
Cardie's Avatar
Cardie
Default Is this Tyre Legal?
Was changing a rear tyre on my corsa, so I checked them all and the front one which is badly warn on the inside (came from front driver side), ive swapped with the spare (good tread), but now ive got 2 tyres, one which has a pretty cracked sidewall, even though it holds air fine, but it only has about 1.9 to 2mm of tread. Whereas the tyre which is badly warn on the inside has about 5mm of tread everywhere else!
I should be able to get another one tomorrow but whats best to use in the mean time?
Badly warn outside but good tread?
Or tatty but legal tread?
Old Jan 17, 2013 | 05:28 PM
doga-ot's Avatar
doga-ot
Nope!!
Old Jan 17, 2013 | 05:29 PM
doga-ot's Avatar
doga-ot
and you need your tracking done, unless your balljoints and track rods need replacing
Old Jan 17, 2013 | 05:39 PM
Acidburn's Avatar
Acidburn
agree above, most likely end up with points for that or it will wear out thru the canvas and blow out depending how quick its wearing
Old Jan 17, 2013 | 06:13 PM
Chopshop85's Avatar
Chopshop85
The law states you need 1.6mm of tread over 75% of the tyre. However, I wouldn't use a tyre that looked like that.
Old Jan 17, 2013 | 06:15 PM
dojj's Avatar
dojj
Resident Wrestling Legend
and with the weather we've been having lately, best to change it now you've gone through the trouble of getting the wheel off
Old Jan 17, 2013 | 06:30 PM
RichieST's Avatar
RichieST
The tyre must have at least 1.6mm across the middle 3/4 of the tyre's width, so if it's for example 145mm wide then a section of 108mm along the middle needs to have legal tread. If the worn section has canvas showing then it's illegal.
I would say by looking at it that it's borderline legal, however you need to get the tape measure out, but just by looking at it I certainly wouldn't want to drive on it especially with the heavy snow that is forecast tomorrow for the most of the country!
Old Jan 17, 2013 | 06:39 PM
Cardie's Avatar
Cardie
Okay thanks!
Ive stuck the legal one on now, (2.0mm of tread).
Old Jan 17, 2013 | 09:13 PM
matthewpickup's Avatar
matthewpickup
for the cost of a tyre that size i would just get a new one
Old Jan 17, 2013 | 09:39 PM
phil_focus's Avatar
phil_focus
Good choice though I would change this one too as cracking is a sign of age so the rubber is probably shit by now. Get them replaced, stick them on the front and get the tracking done in one go otherwise you will go through another tyre VERY quickly!
Mark RS
Mar 5, 2021 06:08 PM
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
