camber on a sierra cosworth question
Old Jan 17, 2013 | 03:56 PM
matthewpickup's Avatar
matthewpickup
Default camber on a sierra cosworth question
Has anyone tried to take the camber off the back wheels ?
Old Jan 17, 2013 | 04:01 PM
dojj's Avatar
dojj
Resident Wrestling Legend
rainbird sells shims, but to do it properly you need a full rear adjustable beam
a tenner for the shims, upto Ł1500 for a beam
you takes your pick and spends your money
Old Jan 17, 2013 | 04:11 PM
matthewpickup
looks like shims haha will do the same job and save the tyres a bit more
Old Jan 17, 2013 | 05:47 PM
Rsmat's Avatar
Rsmat
Mines on billet camber shims and put the power well across the tread no drama instead of the in side edge .
Old Jan 17, 2013 | 06:15 PM
mark r's Avatar
mark r
hi matt, where did you get the shims from
mark
Old Jan 17, 2013 | 06:43 PM
Ade500's Avatar
Ade500
Fixing Fords
They do the job hey mate
A guy on the Fsoc called bettison I think 2005 makes them
Old Jan 17, 2013 | 06:52 PM
tonyRS's Avatar
tonyRS
Did your car settle quickly once you fitted them mate? iv got koni/ahmed on mine and it still squats so iv been looking at these myself, im just scared i end up with opposite camber to what iv got. lol
Old Jan 17, 2013 | 07:20 PM
thebronze's Avatar
thebronze
Blag Master
mark
I'd like to know where too....
Old Jan 17, 2013 | 07:24 PM
dojj's Avatar
dojj
no need to settle the car, you just loosen a few bolts and then tighten them up again
when i did mine in something silly like 93 or 94 i simply put 2 washers behind the bolts to bring the hweels out
those were the days
Old Jan 17, 2013 | 07:27 PM
Ade500's Avatar
Ade500
Fixing Fords
http://forum.fordsierraclub.co.uk/vi...p?f=23&t=40475
Old Jan 17, 2013 | 08:22 PM
Rsmat's Avatar
Rsmat
I get even wear on my tyres so I'd guess there doing the job fine .
I got them off a guy local to me called bettison2005
Mines on koni/bilsteins and Ahmed bajoo track springs and it doesn't squat.
Old Jan 17, 2013 | 10:07 PM
Fil's Avatar
Fil
ELASTIC BAND
just got sent this link
http://www.ebay.co.uk/itm/ford-sierr...OU%3AGB%3A1123
The same person as mentioned above, tho none for sale currently and mentions last sets
Old Jan 18, 2013 | 06:53 AM
Rsmat's Avatar
Rsmat
Mine once fitted....
Old Jan 18, 2013 | 07:03 AM
frsjon's Avatar
frsjon
i want some of these for the fiesta to add some camber to the rear of the car.
Old Jan 31, 2013 | 12:49 PM
Fil's Avatar
Fil
ELASTIC BAND
anyone selling these?
Old Jan 31, 2013 | 04:53 PM
Ade500's Avatar
Ade500
Fixing Fords
Mine will be available once my MK 6 degree beam arrives if you not in a mad rush?
Old Feb 1, 2013 | 12:13 PM
killa_paul's Avatar
killa_paul
how much is the beam costing you if u dont mind me asking
Old Feb 1, 2013 | 01:12 PM
Fil's Avatar
Fil
ELASTIC BAND
If i aint found none by then , ill be interested
Old Feb 1, 2013 | 06:18 PM
Ade500's Avatar
Ade500
Fixing Fords
Ok Fil , I will give you a shout when I pull mine apart. Paul sending a pm now mate.
Old Feb 12, 2013 | 01:59 PM
Fil's Avatar
Fil
ELASTIC BAND
cheers again,
but ive got some on there way now, not sure where from, a mate droped me a text, saying his mate bought 2 sets as he knew i was after some
Old Feb 12, 2013 | 08:56 PM
matthewpickup
hi mate i am intrested in the anti camber shims if there still going?
thanks
Old Feb 12, 2013 | 09:11 PM
Ade500's Avatar
Ade500
Fixing Fords
No worries they should be off soon ish lol
Old Feb 12, 2013 | 09:17 PM
matthewpickup
great thanks no rush
Old Feb 12, 2013 | 09:28 PM
Paul500+'s Avatar
Paul500+
i need some and some good rear springs to stop the squat
Old Feb 15, 2013 | 10:33 PM
mark r's Avatar
mark r
anyone know whos making these shims?
Old Feb 15, 2013 | 11:50 PM
Paul500+'s Avatar
Paul500+
just got a set off bettison think its is last
Old Feb 16, 2013 | 07:59 AM
cossie891's Avatar
cossie891
Great I need some too
Old Feb 26, 2013 | 07:42 PM
Paul500+'s Avatar
Paul500+
i can get a load of these but it wouldent be right to sell them any how as others are already selling them
dont have a traders account aswell
Old Feb 26, 2013 | 07:48 PM
cossie891's Avatar
cossie891
How much can you get them for
Old Feb 26, 2013 | 07:53 PM
Paul500+'s Avatar
Paul500+
dont think its a good idea me getting in to it m8 i would love to help out but as said theres others selling them
Old Feb 26, 2013 | 07:54 PM
MrC's Avatar
MrC
If anyone can get these for a 4x4 please pm me, if they're billet even better
Old Feb 26, 2013 | 08:13 PM
Paul500+'s Avatar
Paul500+
ive contacted the guy i got mine off to see if he is still doing them if he is i will get him to advertise them
Old Feb 26, 2013 | 09:02 PM
fraser9764's Avatar
fraser9764
These arent the same as mike rainbird sells, mikes are very thin toe shims that toe the rear wheels in slightly. This improves tyre wear and gives the rear a more centred feel.
The camber shims may be better than nothing, but not comparable to a six degree beam. They dont correct the toe changes under compression and extension, causing instability under braking etc.
Granted there is a big difference in price though...
Diff mount is also a good investment to improve handling
Old Feb 26, 2013 | 11:21 PM
Rsmat's Avatar
Rsmat
Bang on
Old Feb 27, 2013 | 07:37 AM
charlie luciano's Avatar
charlie luciano
Shims will help the tyre wear but as said I don't think they will do an awful lot of justice to the way the car handles, 6 degree rear beam is expensive but it will be one of the best handling mods you will ever do to the car.
here is a shot of my one prior to fitting and a shot of the rear of the car once it was on, notice how straight the wheels now sit and they sit exactly the same when the car is on the tarmac
Luciano
Old Mar 2, 2013 | 08:48 PM
matthewpickup
imo as standard the front of the rear wheels point in , this could also be changed a little with the correct shim at the same time to make them straight as well as taking camber off but you still want a bit of camber still on them so it straightens up when going round corners
Old Mar 2, 2013 | 08:53 PM
fraser9764's Avatar
fraser9764
the problem is the camber and toe changes with compression and extension. no amount of shims will correct this.
you can set the suspension so its all pointing the right way under a certain situation, but as soon as the suspension moves you are back to square one.
Old Mar 2, 2013 | 09:03 PM
matthewpickup
ah see what you mean mate , but if like me you are running coilovers the car dose not move a great deal so the way the wish bone moves will be very little imo i think the diffrance would be seen mostly on a track car but i guess the diffrent beam is really a track set up as it can be changed for each track or weather , cant wait to get my camber shims
Old Mar 3, 2013 | 09:04 PM
Rsmat's Avatar
Rsmat
Mines having a SCS beam sometime this year ,
Old Mar 14, 2013 | 09:31 PM
mark r's Avatar
mark r
evening people,fitted my rear shims today,no problem.
tried to move car forward and it was jammed/locked.
it seems from where the shims have pulled the drive shafts a little outwards that the bolts holding the cv joints to stub are fouling on the inside of the trailing arm.
anybody else had this problem?!!
if you look at rs mat photo above you will see bolt 1mm from arm
mark
