AEM EMS-4 in a Cosworth?
Old Jan 15, 2013 | 05:26 PM
Yura's Avatar
Yura
Default AEM EMS-4 in a Cosworth?
Do somebody has experience with this ECU?
My mate suggest me EMS-4, cheap ECU with a lot of functions.
Old Jan 15, 2013 | 05:47 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
excelent managment, but, id make sure you know someone who can map the AEM stuff first, otherwise go for it.
seen some big numbers on 4 pots running AEM
Old Jan 15, 2013 | 06:14 PM
Yura's Avatar
Yura
Yes i have experienced guy(evo 8.6s on 1/4mile) who can map it.
I'm not sure is the 4 tooth at crank pulley is good enough.
and how better to get cam timing for ECU?
and now to get car speed for ECU?
May be somebody has an advice please?
Old Jan 15, 2013 | 10:55 PM
stevieturbo's Avatar
stevieturbo
C**t
Explain the question ?
4 teeth on the crank is crap on any engine or ecu. Upgrade to 36-1 or similar.
It is not essential for a cam trigger, but the OEM Ford dizzy can provide a perfectly fine cam signal to work in conjunction with the 36-1 crank trigger. At worst, it may need a small modification, but your tuner will be able to advise.
Road speed can come from a variety of sources. If there is no electrical signal from the diff or gearbox, then you could piggyback off an ABS sensor or similar. Or just install your own trigger on one of the wheels.
Old Jan 16, 2013 | 06:43 AM
Yura's Avatar
Yura
stevieturbo, thank you!
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
