Changing the headlight bulb on a vivaro
I can honestly say that I have never ever driven or worked on such a peice of shit design as the vivaro
Nothing is easy
And you can't change the headlight bulb as they say in the manual without removing the headlight because the cunty windscreen washer bottle filler is situateted directly behind the bulb
What cunt though this though
So what I need from you is to tell me how to do it without using a hammer
Nothing is easy
All modern vehicles are designed to have once simple tasks like this, made very bloody difficult. It's so the average joe then books the car in at a dealer for it to be done at a minimum charge of an hours labour.
Just take a hammer to it dojj!
The washer bottle is in the way
Can't remove it
But the multiplug for the light is behind it
And then you have to remove a rubber cover
Then another clip
Then the light comes out
But before you do any of that, you can't actually see what you are doing because of the shit design
On a transit you remove 2 screws and a plug and the whole headlight comes out, nice and simple
Can't remove it
Then another clip
SNAFU ???
situation normal all fcuked up
I haven't had to do this on a vivaro but I helped on a friends Clio we had to had to take the front wheel off to change the head light bulb
no really I do mean it access was by a removable panel in the wheel arch!
Saves me posting a pic at least lol
But how the fuck did yogurt you hands in there? I can't even bend my arms round enough to get to the plug let along the rubber things
Gary Krishna
Believe me when I say my hands are far from svelte!!
I've got sausages for fingers!! Lol!
I literally had no problem at all Dojj!! I've done it a few times now and never struggled!
Saying that though, I've struggled with stuff in the past and someone else has done it straight away! We all find things easier or more difficult than others.
You know what my answer to you is?
Recall, if you will, the opening scenes of bad boys where Martin Lawrence has just dropped a chip in will smiths porches
Holding up his crooked hand he says something along the lines of "you come up with this shit?!?!?!"
Yeah, that's what I'm talking about
got another one to do
i've undone 3 screws that i can see that seemed to hold the front grille in place, they don't they hold the entire front panel in place
i've undone the 3 screws i can see that hold the headlight in place, the headlight won't come out
fuck it, it's going to vauxhall as none of the lights on that side work
cunty vans
cunty vans
I was lucky, mine was leased through Sky, so didn't cost me to repair!
It went through a few headlight bulbs, 4 rear calipers, power steering pump and a gearbox. Was in the dealers a few times to sort the dash board lights. Crock of shit. Think Renault did the electrics, so no wonder that fucked up! Lol
Got a nice new VW Transporter now
Gary Krishna
cunty vans
cunty vans
Steve Escos
Oct 1, 2015 06:57 AM
