Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
My mk2 escort turbo project
Old Jan 13, 2013 | 05:31 PM
escort_lx's Avatar
escort_lx
Default My mk2 escort turbo project
Heres some pics of my homemade turbo project, 1980 1600 ghia
Mitsubishi td04 water cooled turbo from an old volvo 940!
Homemade log style exhaust manifold with crossflow flanges and garrett t3 turbo flange that i got from ebay
Turbo oil drain to sump which is now a proper threaded fitting rather than the red rtv in the pic lol
Oil feed is fed to the turbo through a custom made pressure hose t-pieced off oil pressure switch, also upgraded to high pressure oil pump from burton
Carb inlet plenum that my mate tig welded up for me from aircraft aluminium
Fuel pump is an electric injection pump from a honda cbf125 bike, malpassi rising rate fuel pressure regulator, unknown dump valve, crossover boost pipe from the volvo slightly modified, volvo 2.5" turbo dump pipe with reducer onto escort exhaust. Vacuum advance removed from dizzy, choke removed from carb, Cheap air filter from ebay, breather plumbed from crankcase to rocker then from oil cap to a can of rockstar lol!
Guages are unfinished at the moment but i have an innovate mtx-l air fuel meter connected to lambda in turbo dump pipe to monitor the mixture, its a bit on the lean side at cruising speed so need to up the main jets slightly. Tim boost and water temp guage, max boost is 0.4 with standard volvo wastegate.
Really happy with how its running, spins up the back wheels through 1st n 2nd gear under boost!
Old Jan 13, 2013 | 05:38 PM
escort_lx's Avatar
escort_lx
Hopefully i will figure out the photo links soon lol
Old Jan 13, 2013 | 05:52 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
nope, dunno what youve done there mate, cant fix it!
on photobucket, click the ticks next the pictures and at bottom of page it says "choose action" then click "generate link codes",
you want "IMG for bulletin boards & forums", Full size
it will automaticaly cut them when you click it, then paste into the post box on here, done!
Old Jan 13, 2013 | 06:00 PM
Cossie Sean
you should maby keep your photobucket account secure lol
Sean
p.s LOVE the africa twin and trans alp!!!!
Old Jan 13, 2013 | 06:23 PM
escort_lx's Avatar
escort_lx
Lol, i'm trying to do it on iphone, its a nightmare lol
Old Jan 13, 2013 | 06:39 PM
escort_lx's Avatar
escort_lx
Sorted, cheers sean
Vincereese
Jun 1, 2023 09:14 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
druidgetafix
Aug 15, 2015 10:22 AM
