mk2 fiesta hydraulic clutch?
I have just converted my fiesta to a 1.7 puma engine which required installing a hydraulic clutch. I then swapped the brake servo over for the brake bottle to connect the clutch to only to discover theres only holes for 2 brake lines because the puma had abs. could I put the fiesta brake system back on, seal up the puma resivoir bottle fill it withs brake fluid and mount it somewhere else in the bay to work the clutch or does it need to be connected to the brake system?
TPM961
Jan 15, 2018 10:50 AM
