Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Ford Escort Rs Turbo Problem
Old Jan 8, 2013 | 07:48 PM
mikersturbz's Avatar
mikersturbz
Default Ford Escort Rs Turbo Problem
My car Will only start when it is cold when its warm it will not start ny idead
Old Jan 8, 2013 | 07:50 PM
marc_gti's Avatar
marc_gti
does it click when you turn the ignition?
mine did this and the solenoid was buggered on the starter
Old Jan 8, 2013 | 07:56 PM
wRenRox_S2's Avatar
wRenRox_S2
I had same problem once car had cooled down was ok starting, changed starter and been fine starter gets very hot being so close to exhaust also fitted heat shield as well not sure if it does a lot but not had problem anymore
Old Jan 8, 2013 | 08:06 PM
Chopshop85's Avatar
Chopshop85
If it is not turning over when hot:
Usually heat soak on the starter. Can wear out the starter or cause the excite wire to corrode.
New starter and a bit of exhaust wrap on the down pipe should see you right.
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
adriansaleem
Aug 1, 2015 09:28 PM
