focus st 08 only quarter boosting
hi please could someone help me here.
i bought a focus st last thurs and everything seemed fine.
boosting to half way, but to day it is only boosting to quarter, so rang ford up they said make sure it is warm. So i did this and yes it boosted to half way but dropped to quater mand stuck at a quarter and wouldnt boost past, does anyone know what the problem is. it still has warrenty from the garage and wanna get this sorted. thanks chris
Ł38 from Volvo
ford wanted Ł58 but most upgrade to this. http://www.pumaspeed.co.uk/product-I...noid_15677.jsp
Ł38 from Volvo
ford wanted Ł58 but most upgrade to this. http://www.pumaspeed.co.uk/product-I...noid_15677.jsphttp://www.efi-parts.co.uk/index.php?productID=222
Would assume you've had this sorted by now but check:
boost solenoid
maf sensor
map sensor
I had the same issue but mine was down to over-fuelling from the wrong map so yours won't be that if it's standard.
If it's none of those then you have a boost/air leak somewhere
boost solenoid
maf sensor
map sensor
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
