Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus front wing fitting
Old Jan 7, 2013 | 08:07 AM
splash550's Avatar
splash550
Default Focus front wing fitting
How easy is it to swap a front wing? I have a slightly rusty wing and thought it might be easier and cheaper to swap it for one from a salvage yard rather than get it painted for the rust to come through again. Plus Metropolis Blue colour match might also be a better match that way. What needs removing to do the swap?
Old Jan 11, 2013 | 06:24 AM
Straight_4_N/a's Avatar
Straight_4_N/a
remove grill then head lights then look from the inside wear the head lights were and undo the wings there then open doors and look inside the door at the wing theres 1 bolt there then jack the car up and take off the wheel and then undo wheel ach liner then feel to the back off the wing roughly where you toke the last bolt out from the door your will feel anther bolt undo that then get on top and undo the last bolts and its off, depending on how good you are could take you less than an hour to do it.
john_3.0s
Aug 15, 2015 07:44 AM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
paceo
12
Aug 4, 2015 08:50 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
