Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
fiesta mk5 door handle problem, its broke..
Old Jan 6, 2013 | 05:48 PM
baxter's Avatar
baxter
newbieeeee
Default fiesta mk5 door handle problem, its broke..
basically the handle just feels loose, if i lift the handle up nothing happens.. doesn't open the door. can be opened from the inside though.
any help would be appreciated.
Old Jan 6, 2013 | 09:09 PM
rallyesport04's Avatar
rallyesport04
need a new handle the plastic lug has snapped off aint to hard to do just strip the door card off there might be a metal cover glued to the door these are a sod to get off i used a sharp knife to remove it
Old Jan 7, 2013 | 07:06 AM
STeve's Avatar
Super Moderator
as said easy job just make sure you get a fiesta handle as they have a hole in them for the lever to go through where as 4 door models on back doors use same type as a mk6 escort which is just a lever
RockinRein
Aug 19, 2015 07:08 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
saph in dorset
Aug 14, 2015 10:10 AM
turbobill
Aug 1, 2015 08:55 PM
