NOS
Old Jan 6, 2013 | 04:08 PM
mechanic28's Avatar
mechanic28
Red face NOS
Ok so its sunday and I am bored!how many peeps on here have had nos fitted to theirs cossies?what was your thoughts on it?any regrets?or just pure smiles?also what hp kits did you have fitted?did you have it so it kicked out when the turbo comes on song,or just to use whenever through the rev range?
Old Jan 6, 2013 | 04:12 PM
Rsmat's Avatar
Rsmat
Mate had a wizards kit on his with a 50 shot..we use to use it to destroy bikes up the bypass... APart from wanting to achieve something like drag strip .. Top speed runs etc...I think it's a waste of time IMO
Old Jan 6, 2013 | 04:14 PM
mechanic28's Avatar
mechanic28
did it make much of a difference being 50hp kit matt
Old Jan 6, 2013 | 04:30 PM
Rsmat's Avatar
Rsmat
Yes made a massive difference when he hit the switch in mid range... The 50 jets are supposed to make 100hp on turbo charged cars iirc
Old Jan 6, 2013 | 04:32 PM
mechanic28's Avatar
mechanic28
cool cheers chapio,been thinking of fitting it too mine for ages now lol mind you it is only thinking lol
Old Jan 6, 2013 | 04:33 PM
Rsmat's Avatar
Rsmat
Ha ha you nutta..
Old Jan 6, 2013 | 04:41 PM
TommyB's Avatar
TommyB
Boosted 122 cu in
My Renault 5 went from a 13.4 to a 12.1 on the 1/4. Gained 10mph to.
That was with about 40HP on a stock engine.
Yes it's worth it, but once you have it, there's no going back.
JonnyBravo's Avatar
JonnyBravo
50hp without a bottle heater can feel a bit naff, I did a 4x4 saph on a T4 which I jetted for around 125hp and it was savage, I do love a bit of gas but the bigger the jets the sooner it runs out and it does then get a bit like a expensive addiction.
As mentioned above good for drag racing but a little pointless for road use
Old Jan 6, 2013 | 04:42 PM
JonnyBravo's Avatar
JonnyBravo
So true
Old Jan 6, 2013 | 05:02 PM
scoooby slayer's Avatar
scoooby slayer
its cheating in a road car, boost and pump fuel is all thats allowed
Old Jan 6, 2013 | 05:07 PM
mechanic28's Avatar
mechanic28
I don't mind cheating lol,was just thinking about having it in the low revs then cutting out when the turbo is on full song?
Old Jan 6, 2013 | 05:35 PM
DangerousBryan's Avatar
DangerousBryan
No reason why you can't use it that way to speed the spool up. Google wizards of nos.
Old Jan 6, 2013 | 05:52 PM
mk2 escort boy's Avatar
mk2 escort boy
I have a kit that you turn it on and when makes a set boost pressure it switches its self of so only comes in when there's no boost never fitted it but very tempted
Old Jan 6, 2013 | 05:55 PM
mechanic28's Avatar
mechanic28
tony planted this seed in my head ages ago its very slowly been growing lol
Old Jan 6, 2013 | 05:59 PM
rhinopower's Avatar
rhinopower
I've had loads of fun with my kit. It was brilliant on n/a, looking forward to running it on my zetec tubo
Old Jan 6, 2013 | 06:07 PM
crazycage's Avatar
crazycage
ive had a kit on my zetec turbo for years , only used it once at the pod with 25hp jets and we data logged the run. we had no bottle heater and it went rich as hell low 10s iirc . fitted some 50hp jets but never had a go after that.
Old Jan 6, 2013 | 06:26 PM
rhinopower's Avatar
rhinopower
The jets Trevor supplies are normally on the rich side, he can supply with a leaner fuel jet if need be
Old Jan 6, 2013 | 06:29 PM
Brendan's Avatar
Brendan
struggling with reality
I have bought the bits and will fit later this year on insurance renew as can't with existing insurance! I will be going for 40 hp in a fiesta turbo. I will have it activated using a gear-stick knob with a guarded switch that will illuminate when on (built it my self! ). I have a controller that I can set so it is RPM and WOT dependent! I have issues with traction if I am flat out in anything but very good conditions in 1st and 2nd. So I am thinking that I can activate on change into 3rd ready for a killer overtake if needed! I have been in a pug 205 GTI with NOS and the kick was very impressive.
Old Jan 6, 2013 | 06:31 PM
crazycage's Avatar
crazycage
yeah i looked into it a bit after that and ordered some bigger jets . i was going to run the fuel jet from the 25kit with the gas jet from the 50kit .fitted them but never got round to giving it go. bottle is empty now tho
Old Jan 6, 2013 | 09:31 PM
whizzisat114's Avatar
whizzisat114
Is it expensive to refill the bottles?
Old Jan 6, 2013 | 09:33 PM
rhinopower's Avatar
rhinopower
i pay Ł60 to refill an 11lb bottle which is pretty big!
Old Jan 6, 2013 | 09:37 PM
whizzisat114
I know its a saft question but how long does it last?
What bhp jets you run?
Is it armed all the time?
Is it switched at full throttle or trigger?
Old Jan 6, 2013 | 09:54 PM
rhinopower's Avatar
rhinopower
I worked it out to be 4 minutes continual use, on 50bhp jets.
I arm it when i want to use it, so either santa pod or for upsetting people on the road
Its triggered through an adaptor on my tps, and activates at wide open throttle only
Old Jan 6, 2013 | 10:13 PM
black_jack's Avatar
black_jack
Black Jack
Depends how big the bottle is and how big the NOS jets are - usually, not very long, that is why its only really suitable for drag racing
There are "dry" kits (NOS only) and "wet" kits (NOS and petrol into the inlet manifold) NOS makes the engine run lean, the bigger the NOS jets the leaner (its an oxegen supply system) more petrol is injected to balance this, the more petrol the richer it gets, its often set up rich to start (to prevent holed pistons and burnt exhaust valves) and gradually leaned off - as others have said the more NOS injected the shorter it lasts - running NOS can find weaknesses in the engine and trasmission
The wet nos kit can be used in conjunction with Methanol and water injection (again more suitable for drag racing)
Not normally (limited supply, remember)
Depends on the system, some are a simple switch at WOT (works surprisingly well), some are WOT + boost, some are more sophisticated
A system that cuts out at high boost has to be carefully matched to the engine mapping/ management to avoid a deminishing power characteristrict
Old Jan 6, 2013 | 10:20 PM
Alg1k's Avatar
Alg1k
I had 150 jets on my gt35 turbod engine
30 psi and a shot of laughing gas is addictive
In fact i like it so much im putting 2 bottles in my new car
Old Jan 6, 2013 | 10:38 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
http://www.noswizard.com/wizard-of-n...re7a4sjiklnf25
Any good anyone?
Old Jan 6, 2013 | 10:56 PM
t16coupe's Avatar
t16coupe
i have got 50 jets direct port on my gtir
Old Jan 7, 2013 | 08:16 AM
rhinopower's Avatar
rhinopower
Originally Posted by Eigdoog
Just a taster to encourage you to buy a full kit really.
I wouldnt use anything apart from a wizards kit, i would stay well away from all the american brands
Old Jan 7, 2013 | 08:20 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Wizards of nos kit with 125bhp Jets on mine with a T34.
Spools quicker than a small turbo escos, makes the power and torque of a good T4 engine.
Only downside is at retail money its about 50p a second to use!
Old Jan 7, 2013 | 08:21 AM
STeve's Avatar
Super Moderator
I say with the way your 3dr is set up Doug go for it, as it will be the real stormtrooper then for sure
Old Jan 7, 2013 | 08:22 AM
Chip's Avatar
Chip
With a 50bhp hit, it will literally only last a couple of seconds.
Cool for putting 5bhp on a moped though
Old Jan 7, 2013 | 10:53 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You don't drive it so no point fitting it
Steve
Old Jan 7, 2013 | 11:44 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Who told you that . Put mine with Nitrous on a RR it made about 80% of jet size so we fitted a 'push' system. If you use a direct port system & then a Nitogen 'push' bottle @ 1500psi the pressure drop can be negated & it becomes very efficient makes around 150% of jet size .
Old Jan 7, 2013 | 11:49 AM
Chip's Avatar
Chip
If you have a turbo charged car that is running loads of boost through a poor intercooler (ie a chipped calibra turbo for example) its not uncommon to massively exceed the rated bhp figures for the jets just thanks to the colling effect.
Also at some points in the rev range you will see MASSIVE gains from spooling the turbo earlier.
Olly clarke for example made 300bhp at the wheels extra on his scooby with 100bhp jets at about 5K rpm.
Basically its very application specific and no general rule of thumb will work for all cars.
Old Jan 7, 2013 | 11:57 AM
Rsmat's Avatar
Rsmat
Hence I stuck "iirc " on the end and said supposed at the beginning ... You could write on the back of a stamp what I know about NOS..
Old Jan 7, 2013 | 12:28 PM
lee2cossies's Avatar
lee2cossies
Go for it, I'm going to put it on my saff when it's finished just for a buzz now and then.
Fitted a wizards of nos kit to my 24v xr4i, power went from 192hp to 248hp with 75hp jets. It feels a lot more than that on the road as the 24v is a lazy old lump so the nos gives it the boot up the rear it needs! With the nos over a distance of a mile it's on par with a e46 m3 which ain't bad for a car built for under a Ł1000 including the gas kit.
Old Jan 7, 2013 | 03:07 PM
gjh's Avatar
gjh
To quote fast and furious "I need nos!"
But I'll make sure I don't blow the welds on the intake manifold
Old Jan 9, 2013 | 02:28 PM
Brendan's Avatar
Brendan
To quote gone in 60 secs "GO BABY GO"
Old Jan 9, 2013 | 07:26 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Why dont you e-mail them and get a group buy, loads of people here seem to want it.
Im one but cant afford it
Old Jan 11, 2013 | 08:28 AM
Chip's Avatar
Chip
Ive done a group buy with Wizards before, I got about 20% off most stuff.
But arranging them is a bit of a ballache TBH as people are forever saying they want stuff and then dont come up with the cash etc.
Anyway I think group buys might fall foul of the rules on here as it would be classed as if I was trading on behalf of wizards if I did another one so I dont think I am allowed to do it here anyway.
If I am I would only do so if people paid 100% of the money up front, I wouldnt do it on a deposits basis again as Ive been too mess around in the past.
