Focus hose part numbers if possible please.
I've just removed the Spec-R header/expansion tank off my car with no dramas and put a nice clean standard Ford tank back on the car. I connected the large pipe back up on the bottom of the new tank but then realised that whoever fitted the Spec-R tank had cut the 2 smaller hoses which means that they are too short to re-connect (bollocks - just when the job was going so well and nearly completed). Does anybody know the Ford finis numbers for both of the "pre-shaped" smaller hoses - outside diameter about 15-16mm - that connect to the top of the standard tank.
The tank is the same as a standard Focus but i'm not sure if the hoses are so just in case, the car is a 2003 MK1 Focus RS.
Thanks guys.
Thanks guys.
Well as nobody got back to me i'll assume that no-one new the numbers so i'm going to educate you all just in case it helps anyone else out in the future
The short hose is Finis number 1134597 and costs £13.82 + VAT from Ford.
The longer hose is Finis number 1226688 and costs £51.92 + VAT from Ford.
In the end i went for a blue silicone set from CarParts Express for about £40 + £8.50 delivery (bargain).
There you go peeps - here ends todays lesson.
borboyous
Aug 22, 2015 11:17 AM
