which way to fit springs
Jan 4, 2013 | 08:36 PM
i have a set of g max springs to fit to my cab only problem i have is the front springs have 3 tight coils one end 3 loose coils the other which way up do they fit on the suspension leg
Jan 4, 2013 | 08:39 PM
I have always put tight coils on bottom on escorts
Jan 4, 2013 | 08:41 PM
I've always fitted springs so the writing on them is the right way up, although to be honest I don't think it matters a great deal.
Isn't there any lettering on the springs anywhere?
Jan 4, 2013 | 08:43 PM
quality makes have arrows but gmax is a budget one so I guess they could not be arsed
Jan 4, 2013 | 09:26 PM
Close coils at the top so the lower ones act first and as you reach/create more compression the upper tight coils react last/least.
Jan 5, 2013 | 09:31 PM
No difference at all
How would the spring know if the wheel was moving upwards or the body of the car was dipping down
Jan 7, 2013 | 12:18 AM
Quote:
Originally Posted by
sierra1off
I tell thee springs know !!
Jan 7, 2013 | 01:33 AM
tight coils compress easier than ones with bigger gaps and should always be fitted with the tight coils to the top!
Jan 7, 2013 | 06:17 PM
Chaz888
Excellent !!!!
Do your springs come from MERLIN Motorsport
Jan 7, 2013 | 08:34 PM
sierra1off
so if only one corner hits a bump then the full car pushes down on that one spring?
i'd say tight to the top?
Jan 7, 2013 | 08:53 PM
Of course it makes no difference which way up they are fitted, they will compress exactly the same, it is just simple physics. But as said, I've always fitted them so the writing on them faces the right way up.
Jan 7, 2013 | 09:33 PM
When I fitted my Eibachs, stuck them on writing faceing up and the tighter coils were at the bottom...
borboyous
Aug 22, 2015 11:17 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
