Massive spec Rs turbo project... 300+ hp cvh, mtx and much more.... Breaking!!!
Time to sell my unfinished project.
Please note.. The car is a rolling shell and requires only a rear custom mount to fit the mtx box! All the rest is complete to make a proper cvh powered track weapon!
Please no negative comments on how much you think it's worth etc or silly offers.
If you are serious please contact me on 07969443979
Due to a change in circumstances I am breaking my massive spec rs turbo.
This car has had no exspense spared and really would have been one of the best around.
Please understand that 90%of this car is brand new!
Please see my resto thread so far.
The shell had all the welding done to a useable standard and completely stone chipped underneath. inner wing has been cut for mtx box and back part of sun roof tray for cage.
Shell will come with:
All doors with wing mirrors
Boot
Bonnet
Painted fuel tank
brake lines etc
Brand new ford clips underneath
Powder coated suspension, with yellow poly bushes
Carpet
Full performance 4 plastics polycarb window kit, these are brand new.
Brand new safety devices 6 point bolt in cage
Gaz coilovers
MEF tca's
dash cut to fit around cage
cossie rear disc conversion
Comp th2's in satin black with toyo 888 tyres 205/45/17
Wilwood superlite 4 pots with 300mm discs, almost new
Cobra evolution pro buckets on rs turbo subframes and TRS 6 point harnesses (brand new)
Rare Turbo Technics anti roll bar, powdercoated silver and black
Mtx diesel box fully rebuilt with new bearings etc
quaife diff
dave mac drive shafts
2.0 zetec flywheel
Focus rs AP organic clutch kit
spacer plate to allow cvh fitment
came from Jim Gibbs car £1300
Massive spec cvh engine from Jim Gibbs car:
1600 cvh, done less than 800 miles since built!
PEC Rods
Wossner Pistons
Nick waples head and matched inlet
SCS spec cam
SCS spec inlet
Ford Green Giant injectors
Stage 3 T3
Standard 1.25 balanced crank
New Gen Ford oil pump
Twin core cossie cooler and custom pipe work
Air filter
Swirl pot, fuel pump and lines
Air injectors
Pectel T2 managment
made 303hp on there engine dyno
Roose motorsport water hoses, black NEW
Roose motorsport auxillary hoses, black NEW
Roose motorsport boost hoses, black NEW
Standard rears lights
Standard indicators
Standard side repeaters with looms
Mocal oil catch tank in blue NEW
Airtec alloy rad
GRS Evo 5 intercooler NEW
Autospecialists cossie T3 cone filter in black NEW
Bailey header tank in wrinkle black
Bailey breather in wrinkle black
Oil cooler and custom ducting with aeroquip fittings and thermostatic oil switch
will be listing more as i remember
Price is £7500 firm. This is a fraction of the cost to build one to this spec
thanks for looking
Boot
Bonnet
Painted fuel tank
brake lines etc
Carpet
Gaz coilovers
MEF tca's
quaife diff
2.0 zetec flywheel
PEC Rods
Wossner Pistons
SCS spec cam
SCS spec inlet
Stage 3 T3
Air filter
Air injectors
Pectel T2 managment
Standard indicators
Airtec alloy rad
thanks for looking
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
for an rs turbo that doesnt go...
