anyone used one of these.....................
Old Jan 3, 2013 | 07:33 PM
H15 FSC's Avatar
H15 FSC
Default anyone used one of these.....................
rally GPA Sapphire & Escort RS Cosworth YB RHD clutch cable://r.ebay.com/gX73WA
im having loads of trouble with getting my clutch to pull up all the way. these are adjustable so hopefully be ok. would it still use the ratchet an paw.
cheers
Dan
Old Jan 5, 2013 | 02:28 PM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
Have you removed the pedal box to check for cracks ...also the teeth o on the self adjuster ... cables cook and rot then become stick or snap....also pull threw the bulk head on hd cluches ...
cheeRS Carl
Old Jan 6, 2013 | 01:52 AM
H15 FSC's Avatar
H15 FSC
cheeRS Carl
yeah took it all out, cable seems fine moves freely. its a 2wd cable but seems to long. teeth are all good on ratchet and paw.
Old Jan 6, 2013 | 02:02 AM
botters's Avatar
botters
competant bodger
a hydraulic clutch conversion is one of the best mods you can do on a cossie mate
Old Jan 6, 2013 | 02:16 AM
H15 FSC's Avatar
H15 FSC
can it be done with the engine in place, as there don't look like there much room to drill
Old Jan 6, 2013 | 02:24 AM
botters's Avatar
botters
competant bodger
yeah you can do the drilling from inside with the pedal box and lower dash out and the slave cylinder can be bolted to the outside of the box
Old Jan 6, 2013 | 02:43 AM
H15 FSC's Avatar
H15 FSC
nice one mate, will have to sort this as its pissin me right off
Old Jan 7, 2013 | 06:51 AM
carl/saff's Avatar
carl/saff
You saph 2wd ?
Old Jan 7, 2013 | 07:16 PM
H15 FSC's Avatar
H15 FSC
You saph 2wd ?
its a 4x4 conv to 2wd with T5 box
Old Jan 8, 2013 | 03:26 PM
carl/saff's Avatar
carl/saff
Any pics of offending items ....?
