How to test a Dump Valve
Old Jan 1, 2013 | 06:56 PM
maxturbo's Avatar
maxturbo
Default How to test a Dump Valve
Hi,
I purchased a Forge Dump valve from somebody many years previous and I was told it was working. I never fitted it to any car since and I was thinking of selling it now.
How do I test if this Dump valve works without fitting it to a car. Any help would be appreciated.
Old Jan 1, 2013 | 07:57 PM
Brendan's Avatar
Brendan
struggling with reality
if you have a vacuum pump you can test it to see if it moves the piston (connect to small connector). It should open it a bit, you should also be able to move the piston with your finger in the bigger hole. (any Air conditioning engineer / installer will have a vacuum pump
If you have access to a compressor you can test the positive side by letting it blow some pressure off.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
