some info on my saff G66 CJM
i know a few guys on here know this car,
having troubles this a few bits, alarm and the 2wd conversion it had.
and just general info on the car like paint work of any damage its had. its very straight so dont think its been repaired.
cheers
cheers
Tony Taylor had it for a while then sold it to Evorich.
Evorich did the 2wd conversion when he had it.
DANNY-B bought it from him.
Phil/Ima/Boschman bought it from Dan and took some nice bits off it in favour of making it a more standard car.
I was thinking of buying this when it was up for sale but got the chance to buy the one I got now , but still a cracking sapphire you have there
cheers guys.
has it had an engine change, not managed to see the engine number as yet .
but it now has a 2wd rocker cover on,but has 4wd head and 200 block.
has it ever had a rebuild (thats if the engine is the same one). it feels a bit laggy seems its on a T3.
plus did this car come with a lambda as std, I'm unsure as my old H plate one didnt have one.
this car has 2 alarms a cobra and a very old alarm (ford i think) its massive just says 98 on it. there both playing up some times the car starts sometimes it don't .
would like to know who was the last person to have it before the guy i had it off.
its in good nick, im just a bit anal so will probley pull it to bits.
Before it moved to Sunderland and it's 2wd conversion it was brought into NMS with a miss fire that turned out to be that the engine had been miss timed in a cam belt change by one of the owners friends and thus bent most of the valves. NMS repaired and ported the head, fitted a T4 and remapped the car . It was on its original btm end and the power was capped due to the transmition and comp ratio of the engine. Was a real nice straight car when I last saw it .
